Project of the Month built by dnalot
Home Model Engine Machinist > The Tools and Tips > The Shop > Setting up Shop Questions - from an NZ learner
Old 04-18-2017, 07:21 PM   #511
joco-nz
joco-nz's Avatar
Liked 75 Times on 58 Posts
Likes Given: 74
Default
Norm - no offence at all!
Adding some length to the "loose angle thing" is on the list as is a tensioning bolt for when its trying to clamp on somehting that doesnt go past the point of rotation.
I've managed to get by without having to tension/untension stuff too much. But you are right having to reach for a spanner is wearing thin.
There are other mods by a fellow kiwi that I like the look of which are shown here: http://www.modelenginemaker.com/inde...ic,6363.0.html
I also have some ideas re leveraging this big ass frame to create some flat support/mounting space to the right of the blade (look at the saw from clamp handle end). If do that then I get the ability to mount some big rounds of steel or caste iron to be sliced off in a single cut for such things as fly wheels in a single cut. Where as at the moment I need to muck about with a fussy multi cut process as the boom hits the top of the round.
All good fun.
J.
James,
Wellington,
New Zealand
joco-nz is offline
Old 04-18-2017, 08:56 PM   #512
bruedney
Liked 10 Times on 7 Posts
Likes Given: 29
Default
Might have to get you to build me one of those.
bruedney is offline
Old 04-19-2017, 01:24 AM   #513
DJP
Liked 47 Times on 41 Posts
Default
Your frame looks sturdy enough to stand on which is a good thing. When cutting with the blade vertical I need to place my knee on the saw bed to prevent it from tipping backwards. The weight of the motor and gear box hang out enough to make it tippy.
You may need to stand on your frame when pushing a work piece into the blade. Now would be the time to weld on extra custom provisions if you need them.
DJP is offline
Old 04-19-2017, 02:24 AM   #514
joco-nz
joco-nz's Avatar
Likes Given: 74
Default
DJP - good points and I have some ideas for rapid deployed feet to help with leveling on crappy garage floors and deal with the inevitable small amount of twist in the welded frame.
On the tipping side I deliberately designed to cope with the. The base goes back a little further than where the motor hangs when boom is vertical. Net effect is I have wheels slightly beyond he heavy motor meaning its pretty dang stable.
Still have more welding to do for add ons. Which should see me finishing up this bottle of co2/argon. Then its onto to pure argon and TIG welding for some new fun. :-)
James,
Wellington,
New Zealand
joco-nz is offline
bazmak Likes This
Old 04-19-2017, 08:56 AM   #515
joco-nz
joco-nz's Avatar
Likes Given: 74
Default
It's a little over engineered, but its rather nice and SOLID.
James,
Wellington,
New Zealand
joco-nz is offline
Old 04-19-2017, 09:03 AM   #516
bruedney
Likes Given: 29
Default
Over engineered - by you - never!!!
bruedney is offline
Old 04-26-2017, 10:32 AM   #517
joco-nz
joco-nz's Avatar
Likes Given: 74
Default
Some more good progress with the switch being remounted and a new fitting to "knock" the off button in its new position.
The base fits nicely on the finalised mounting tabs (set on the inside of the casting base) with the bolts nuts welded on to to angled tabs.
Now to start working on the cut off support table.
Click image for larger version
Name:	bandsawcart - 1.jpg
James,
Wellington,
New Zealand
joco-nz is offline
Auskart Likes This
Old Yesterday, 08:02 AM   #518
joco-nz
joco-nz's Avatar
Likes Given: 74
Default
Some more progress. Key steps forward being:
[1] Frame painted up
[2] drip tray secured in place with drain plug installed to support coolant system
Name:	bandsawcart - 2.jpg
[3] new mounts for switch and the cut depth stop
Name:	bandsawcart - 3.jpg
[4] version 1 of a cutoff "table" built and installed
Name:	bandsawcart - 4.jpg
Name:	bandsawcart - 5.jpg
James,
Wellington,
New Zealand
joco-nz is offline
bruedney Likes This
Learner in Houston says hello Naiveambition Introduction 1 03-13-2013 03:37 AM
Setting up a VFD? lazylathe General Engine Discussion 64 04-07-2012 02:31 AM
setting top slide firebird General Engine Discussion 4 12-11-2008 10:38 PM
Setting up my new shop Bogstandard The Break Room 246 09-23-2008 01:21 PM
Setting up shop. Tin Falcon Tips and Tricks 4 12-23-2007 05:18 PM
