Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > General Engine Discussion > Help needed: stirling/flame licker engine cocktail shaker
Old 01-23-2018, 05:12 PM   #1
Cocktail
Default Help needed: stirling/flame licker engine cocktail shaker
Now this could be fun!
I have no technical expertise in building stirling or flame licker engine accessories, just a cool idea. I'd like to have a stirling or flame licker model power an old fashioned hand crank butter churner, which would mix a cocktail.
Here is a link to a butter churner:
https://www.bedbathandbeyond.com/sto...kaArMFEALw_wcB
As far as a visual layout, I am envisioning that the two pieces would sit along side each other, with the pulleys, belts, etc. connecting them in between. Kind of like this:
The pulleys, belts, etc. may have to be on something placed in the middle, like this:
Because the butter churner uses gears, maybe there would be a gear attachment rather than a pulley that powers a gear on the churner, or maybe pulleys power the churner handle instead of a churner gear. I donít know.
Another option may be a rotary tumbler. Here are links for a DIY rotary tumbler:
http://myfavoritestripper.blogspot.com/ ... rt-ii.html
The main issue, it seems to me, is to select a pulley, or combination of pulleys, that converts the high speed turning of the wheel on the engine to the lower speed required to mix a drink in the butter churner.
The main issues, it seems to me, are:
1) To select a pulley/gears, or combination of pulleys/gears, that converts the high speed turning of the wheel on the engine to the lower speed required to mix a drink in the butter churner.
2) To have an engine with enough power to mix the drink. I haven't bought a model yet. There are many available. I'm trying to figure out if any of them would be powerful enough.
I have two questions:
1) Do you think this technically feasible?
2) If so, I'd like to pay one of you to build it. If you are interested in doing so, please send me a private message.
Thanks and cheers!
Cocktail is offline
Old 01-24-2018, 12:34 AM   #2
JCSteam
Liked 57 Times on 51 Posts
Likes Given: 297
Default
It does sound a bit of a fun idea, I would recommend belts and pulleys over gears, as gears are very good at sapping power from a drivetrain.
Maybe a triple pulley driving a triple pulley so as reduction/verses drag could be played around with. Or a drink could be gently or vigerously mixed.
My thoughts would be a pair of rollers, with a drum for the drink. , this could be a screw together assembly with an o ring seal, the drum then just sits on the rollers and you have minimal friction. The rollers could be small relative to the drum containing the drink, and thus a further reduction ratio in turning say a 2" barrel, with two 3/8" rollers.
I would be a little concerned about power output, most flame lockers, sterling engines are quite underpowered when compared to a steam engine of similar size.
Good luck and I hope the drinks are on you ��
JCSteam is offline
Old 01-27-2018, 08:28 PM   #3
neil_1821
Liked 3 Times on 3 Posts
Likes Given: 5
Default
I would be inclined to agree with the above comments, belt and pulleys would work far better than gears not to mention the cost. Gears are very expensive unless you have the capability to make your own!
I fear the power output from these type of engines won't be enough to accomplish what you're thinking. I myself built a stirling engine and the smallest bit of friction would cause it to freeze. I experimented with plastic pistons as well as metal one's in honed cylinders but it wouldn't work. In the end I had to use a graphite piston in a glass cylinder. If you so much as rest a finger on the flywheel it will stop.
I think your best alternative would be something steam powered, maybe a little beam engine, although again i'm skeptical on the power as i have no experience with these.
neil_1821 is offline
Old 01-27-2018, 10:35 PM   #4
fcheslop
Liked 114 Times on 89 Posts
Likes Given: 7
Default
http://www.myersengines.com/engines/...engine_1-d.htm
Finding someone to build it or a similar engine for a few bucks maybe the problem
Good luck
fcheslop is offline
V-4 Flame Licker, Vacuum engine, Avaleur de Flame BronxFigs Plans 30 10-31-2014 04:30 PM
Flame licker, stirling first time build heeeelllp ben General Engine Discussion 2 04-16-2013 11:21 PM
'Poppin' Flame Licker Engine NickG A Work In Progress 139 01-29-2011 08:39 AM
Flame licker engine dparker Engines From Castings 7 02-07-2009 01:35 AM
plans for stirling, IC, flame licker from Netherlands rake60 Plans 0 12-17-2007 02:04 AM
