Home Model Engine Machinist > Showing Them > A Work In Progress > PeeWee V4 slow build
Old 01-14-2018, 11:30 AM   #161
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 683 Times on 509 Posts
Likes Given: 69
Default
Al,
If you are using WD40 for aluminium most of the time, then paraffin (kerosene) is a lot cheaper and works just as well, in fact better sometimes than WD..
If you don't try it, you will never know if you can do it!!
Blogwitch is online now
Cogsy Likes This
Old 01-15-2018, 04:56 AM   #162
Cogsy
Cogsy's Avatar
Liked 486 Times on 378 Posts
Likes Given: 477
Default
Thanks John. I'll grab a bottle next time I'm at the hardware (it's no longer available at petrol stations round here as far as I know) and give it a whirl. My wife doesn't appreciate the smell of WD40 on my clothes when I come in from the shed - in fact she claims I "stink" - so the kerosene might solve that issue as well.
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 01-15-2018, 01:46 PM   #163
Cogsy
Cogsy's Avatar
Likes Given: 477
Default
At this point I could bolt the sump on and use the previously machined strip to indicate the front of the block nice and square. The overhang of the front of the sump was a convenient way to pick up the exact bottom surface of the block as well.
Click image for larger version
Once I machined the front face down to final dimension, the centre of the block along the bottom (if that makes sense) was then picked up so the crank tunnel could be drilled, bored and reamed to 1/2" and the cam tunnel was similarly drilled and reamed in reference to the crank.
Next step was the boring of the gear recesses. This engine uses an idler gear in the geartrain so the camshaft rotates in the same direction as the crank does. I assume it was designed this way to give a nice vertical separation between the crank and cam while also keeping the individual gear sizes relatively small.
The timing cover mounting and associated accessory holes were drilled and tapped at the same time while I still had the crankshaft centre point as a reference.
Finally, the block was flipped over to the back face and again indicated off the previously machined strip. The whole face was then taken down to final dimension and (although they're not in the picture) the 2 rear coolant holes were drilled and tapped. Apart from 2 bell housing adapter holes which have their placement determined later in the build, the front and rear block faces are now complete. So far, so good.
Al.
Cogsy is offline
2
People Like This
Old 01-15-2018, 06:13 PM   #164
deeferdog
Liked 207 Times on 84 Posts
Likes Given: 45
Default
Looking good AL, I like your work. Cheers, Peter
deeferdog is offline
Cogsy Likes This
Peewee V4 stevehuckss396 A Work In Progress 276 03-22-2014 12:23 AM
Demon V8 Slow Build Maxine A Work In Progress 73 07-05-2013 04:21 PM
Question for Steve Huck on PeeWee V4 Cam kuhncw General Engine Discussion 2 11-11-2011 04:26 AM
Plans and castings for PeeWee jimmy-1 Buy / Sell / Trade / eBay 3 02-14-2010 09:34 PM
How Slow Can You Go bretk Photos and Videos 49 07-08-2009 02:26 PM
