Project of the Month built by TonyM
Home Model Engine Machinist > Showing Them > Finished Projects > Corliss steam engine
Old 09-24-2017, 05:55 AM   #11
kadora
kadora's Avatar
Liked 281 Times on 111 Posts
Likes Given: 484
Default
Well done Mirek
kadora is offline
Old 09-25-2017, 02:09 AM   #12
lathe nut
Lathe Nut
lathe nut's Avatar
Liked 35 Times on 34 Posts
Default
Mirek, thanks for the plans, If I were to make one sure would not look as good as yours, man that is nice, got a lot of hours in it, something to be proud of.
This is some pictures of the one I run when I was a young fellow a lot younger than that picture, when I was installed in 1895 on a water pump it flooded 10,000 acres of Rice land, it was first run on wood they had a crew of men that cut wood year round to keep if feed only running it about 5 months a year, then early 1900's it was switched to crude oil, the first well was drilled in Louisiana, USA in 1901 then about 1960 it was converted to natural gas, had a 2" line feeding and it would roar, we run it until 1972 put in a V-12 engine, would not pump as slow nor as fast as the steam engine, those rope groves where I have my hand that is where the 2" rope would drive to the pulley that was at the river bank, it was one continues rope, there was a large pulley before and above where I was standing, it would take the rope off the left side of the flywheel and put it on the right side, the big wheel was on 45 degree angle and had weight to keep tension,I am glad that I seen that in my life time.
th_steamengineflywheel[1].jpg   th_steamenginevalves[1].jpg   th_steamengine[1].jpg
lathe nut is offline
oilmac Likes This
Old 09-26-2017, 12:59 PM   #13
sdju
Saun
sdju's Avatar
Liked 15 Times on 3 Posts
Default
I absolutely like your machine Mirek. Everything on the layout is well built and the engine runs well. I like the detail work as well.
sdju is offline
Old 09-27-2017, 10:03 AM   #14
Dr Jo
Dr Jo's Avatar
Liked 16 Times on 16 Posts
Likes Given: 8
Default
Pleased to hear another of our MEM Corliss engines has been finished
The full build of the first of these engines is available here: http://www.modelenginemaker.com/inde...ic,1333.0.html
Jo
Dr Jo is offline
For Sale: partially completed Corliss Steam Engine JoeWho Buy / Sell / Trade / eBay 5 09-16-2016 05:40 AM
Corliss steam engine plans atwatterkent Plans 15 03-26-2016 12:18 AM
HELP: How-to set the valves on a Corliss engine Philipintexas General Engine Discussion 2 05-06-2013 11:31 PM
Lane & Bodley Corliss steam engine castings A1MACH Engines From Castings 8 06-08-2012 11:29 PM
Corliss Engine Build MachineTom A Work In Progress 18 02-21-2011 10:53 PM
