Project of the Month built by Rustkolector
Home Model Engine Machinist > Showing Them > Finished Projects > Bruce-MacBeth Gas Engine Electric Plant
Old 02-29-2012, 09:19 PM   #21
Nickademusss
Liked 6 Times on 6 Posts
Default Re: Bruce-MacBeth Gas Engine Electric Plant
Thats great looking and sounding, I even love the vintage looking lights your powering!
Great job!
Nickademusss is offline
Old 03-02-2015, 02:05 PM   #22
BronxFigs
Liked 54 Times on 47 Posts
Default
Question:
If a two-cylinder version of this engine was to be built from the published drawings, what would be the best crank configuration? Just asking.
Frank
BronxFigs is offline
Old 03-03-2015, 03:57 PM   #23
TorontoBuilder
TorontoBuilder's Avatar
Liked 79 Times on 59 Posts
Likes Given: 140
Default
Originally Posted by BronxFigs View Post
Who can argue with that? Thanks for the suggestions...I think.
The question still stands.
Frank
Haha that's funny.
But just so we all know, that post is not suggestions for you but rather ineffectual spam for construction contracting services in Haiphong Vietnam. A moderator should delete that post.
"Live as if you were to die tomorrow. Learn as if you were to live forever."
TorontoBuilder is offline
Old 03-03-2015, 09:16 PM   #24
Charles Lamont
Liked 113 Times on 79 Posts
Likes Given: 14
Default
That is a lovely job, and it makes such a refreshing change to see, and hear, a model ic engine working under a proper load instead of just ticking over or being revved.
Charles Lamont is offline
Old 03-04-2015, 03:13 PM   #25
johanvanzanten
senior member
johanvanzanten's Avatar
Liked 8 Times on 4 Posts
Default
Hi Jeff,
Well done, runs very good with a lovely sound. What do you think about a period switchboard and some tiles on the floor?
Do you start it by hand or with the use of a power drill?
Anyway a very successful project. Heat off !
Kind regards,
Johan.
johanvanzanten is offline
Old 03-12-2015, 02:27 AM   #26
Rustkolector
Liked 85 Times on 40 Posts
Default
Hi Johan,
A switchboard and tile floor will be part of the my current project. It is progressing now. The Bruce-MacBeth usually starts easily with a few turns by hand. It runs on propane, which helps.
Jeff
Rustkolector is offline
Old 03-12-2015, 11:07 AM   #27
BronxFigs
Default
Re: Posting # 22:
Hoping some forum members will speculate, or offer opinions regarding the crankshaft configuration for a modified, two-cylinder, version. One piston up, the other down... both up....??
Thanks,
Frank
Old 03-12-2015, 11:37 AM   #28
gbritnell
gbritnell's Avatar
Liked 545 Times on 526 Posts
Default
Hi Frank,
Just some random thoughts. With a 180 degree crank you would stand a better chance of balancing due to mass up, mass down. Some Triumph motorcycle engines were 360 degree cranks, both up at the same time and operated fine. It's just that more counterweight is needed. Personally if I were to build one I think I would go with the 180 crank. You will also get a different firing cadence with the two configurations.
gbritnell
Talent unshared is talent wasted.
gbritnell is offline
Old 03-12-2015, 03:41 PM   #29
BronxFigs
Default
G. Britnell-
I appreciate the input, and for the explanations regarding both crankshaft options.
Frank
Old 04-29-2015, 01:01 AM   #30
DickInOhio
DickInOhio's Avatar
Liked 98 Times on 35 Posts
Default
Beautiful engine. did u build the radiator or modify and existing product?
DickInOhio is offline
Electric Solenoid Engine n4zou The Break Room 10 04-10-2013 08:53 PM
Bruce-MacBeth gas engine model Rustkolector Photos and Videos 6 09-14-2011 02:22 AM
The "Bill" Electric Plant Rustkolector Photos and Videos 28 11-24-2009 02:17 AM
Electric Power Plant Tour cobra428 The Break Room 7 10-23-2009 01:45 AM
Model engine builders meet at Georgetown Steam Plant, Seattle, Wa. JackF General Engine Discussion 0 03-09-2009 06:26 PM
