Home Model Engine Machinist
September 02, 2010, 09:16:12 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
  Home Help Search Calendar Login Register   *
Recent
[Today at 09:07:06 PM]
[Today at 09:04:46 PM]
[Today at 08:57:45 PM]
[Today at 08:52:47 PM]
[Today at 08:48:59 PM]
[Today at 08:46:43 PM]
[Today at 08:30:56 PM]
[Today at 08:16:51 PM]
[Today at 07:45:45 PM]
[Today at 07:29:38 PM]
Last 5 Shouts:
August 28, 2010, 12:56:10 PM
Duh...I now know how NOT to wire up a cap!!!!
August 28, 2010, 12:55:29 PM
Boy do I know how to let the smoke out....ugh..I give up...
August 20, 2010, 10:47:44 PM
And if you don't know what to look for...then you need some proof of citizenship.
August 19, 2010, 10:25:01 PM
For proof of citizenship...just ask them to supper...and observe.
August 19, 2010, 08:12:30 PM
Wrong family. I'm not worried.
Pages: [1] 2 3 ... 10   Go Down
  Print
Author Topic: Finished modeling up engine, now time to build.  (Read 9092 times)
0 Members and 2 Guests are viewing this topic.
doc1955
Project of the Month Nominee
Senior Member
Karma 6
Offline Offline
Jamestown North Dakota USA
« on: December 30, 2009, 01:45:05 PM »
Well I'm just about finished modeling up a walking beam engine. I started with Oldboatguys and changed a lot of it to my take and checked clearances and linkage lengths and such.
Going to start to build one for a birthday gift.
<a href="http://www.youtube.com/v/dQp9-VPxASk" target="_blank">http://www.youtube.com/v/dQp9-VPxASk</a>
« Last Edit: January 14, 2010, 11:37:54 PM by doc1955 » Logged
Doc
Jamestown ND   USA
Never too old to learn a new trick.
m_kilde
Advanced Member
Karma 2
Offline Offline
WWW
« Reply #1 on: December 30, 2009, 01:57:38 PM »
Hi Doc
Nice show - thank you !
What CAD are you using ?
Logged
doc1955
Senior Member
Karma 6
Offline Offline
« Reply #2 on: December 30, 2009, 02:21:46 PM »
I use NX6 Unigraphics I can export to a lot of different solids.
I've gotten spoiled I model most things p before I go into build mode to check everything out and add my take on things. When i get project built I'll do some drawings.
I use to scribble some design on a piece of paper and adjust as I went but Like I said I now am spoiled and have to do a lot less adjustments I do them in the virtual world instead.
Well I'm heading to the shop and try and get some thing done today.
Logged
Doc
Jamestown ND   USA
doc1955
Senior Member
Karma 6
Offline Offline
« Reply #3 on: December 30, 2009, 06:41:34 PM »
Well I decided to build 2 engines one for a birthday gift and one to add to my own collection.
I didn't have any plate stock the proper thickness so I took some .250 I got the material to size and started drilling holes at all the corner locations. I'll use them to line up all the angle cuts by putting pins through the holes and pull them up to a straight edge and clamp them down and mill from hole to hole.
I'll do that tomorrow and I'll post some pics.
PS  I here is a little tip  you may or may not already use but I have done this for some time. When drilling small holes and switching from center drill and back to drill I use to constantly drop or lose one or the other.  So I grabbed a magnet and place it on top of my vise an there you go you have a small tool holder to keep them from getting knocked off or dropped. Anyway just thought I'd mention it. Works extremely well when machining non-magnetic material not so good with magnetic.
Logged
Doc
Jamestown ND   USA
doc1955
Senior Member
Karma 6
Offline Offline
« Reply #4 on: December 31, 2009, 05:39:57 PM »
Cut out side plate windows and profile.
I used a piece of aluminum plate for a holding jig.
I lined up a 1/4 cutter with edge of holding jig. Then loaded side plates using 2 the 1/4 holes with pins up against the jig edge. Things went pretty good.and I now have the side plates done as far as I'm going with them untill I get them put together. I will then drill holes for mounting the shaft and link mounts.
« Last Edit: December 31, 2009, 05:43:31 PM by doc1955 » Logged
Doc
Jamestown ND   USA
doc1955
Senior Member
Karma 6
Offline Offline
« Reply #5 on: December 31, 2009, 05:47:07 PM »
Here I'm cutting the surfaces that the bearing mounts get attached.
And the sides with all windows cut out next I'll do the spacer shafts.
Logged
Doc
Jamestown ND   USA
doc1955
Senior Member
Karma 6
Offline Offline
« Reply #6 on: January 01, 2010, 07:38:03 PM »
Didn't get a lot done today. Did get the spacers parted off faced to length and drilled and taped each end.
I turned a groove in each end and milled a hex to give them the illusion of a jam nut.
I assembled side temporary I am going to order some hex head machine screws didn't have any on hand.
Going back out in the shop to see if iI can get started on the cylinder mounting blocks next.
Logged
Doc
Jamestown ND   USA
ariz
Senior Member
Karma 10
Offline Offline
Mantova, Italy
« Reply #7 on: January 02, 2010, 02:42:44 PM »
good start on the engine doc, I built it too and I'll look forward on your progress
very good work on the cad drawings too, I would like to learn it but till now my attempts were unsuccesfull  Undecided
Logged
doc1955
Senior Member
Karma 6
Offline Offline
« Reply #8 on: January 02, 2010, 06:16:46 PM »
Thanks!
I do cad for work I'm a tool design engineer by trade.
Well I got the mounting blocks for the cylinders done and the cylinders.
Shot of the slot milling. I milled slots the original was holes but I changed it to three slots.
Here they are mounted into frame.
Next I'll start on bearing mount blocks for the crank and beam.
Logged
Doc
Jamestown ND   USA
doc1955
Senior Member
Karma 6
Offline Offline
« Reply #9 on: January 03, 2010, 07:16:30 PM »
Well I was busy in shop today last Christmas vacation will be over tomorrow and back to work  Cry
So I'll only get a couple hours in the shop every day I'm hoping to get these done by the 15Th I'm going to have to pick up the pace.
Today I did the main bearing mounts.
I had some .5 x1.0 brass just begging to get used so here we go.
I cut pieces off the width of the bearing mounts. The .5 thickness of material will be sufficient for both top and bottom halves.
cut the mounting tabs to a thickness of .125 plus drilled mounting holes.
cut the width of top halve.
Separated the halves.
They fit together nicely.
I hand ground a form cutter for the top radius.
Assembled and ready for the .250 dia hole.
Milled up a little jig to hold part in vise while drilling.
Finished assembly.
Hope I not boring everyone to death here.
Logged
Doc
Jamestown ND   USA
ksouers
Code Monkey / Project of the Month Nominee
Senior Member
Karma 21
Offline Offline
St. Charles, MO USA
WWW
« Reply #10 on: January 03, 2010, 07:20:51 PM »
Not boring at all, Doc.
I'm quite impressed. Man, that's some tiny work!!  bow down
Logged
Kevin
I make things.
Vernon
Senior Member
Karma 22
Offline Offline
WWW
« Reply #11 on: January 03, 2010, 07:38:18 PM »
Boring? No way, thanks for sharing your progress!
Logged
Chesapeake, Virginia, USA, Northern Hemisphere, Earth, Sol system, Orion Spur, Milky Way.
Sherline 5400 mill, Xylotex drivers and EMC controller
Sherline 4400 lathe, Gecko drivers and EMC controller
ozzie46
Senior Member
Karma 9
Offline Offline
Ron Pueblo,CO
« Reply #12 on: January 03, 2010, 07:42:09 PM »
 Boring?  No no no, That is a very good looking rod and everything else is right on too.
Keep up the good work.
Ron
Logged
zeeprogrammer
Senior Member
Karma 160
Offline Offline
West Chester, PA, USA
« Reply #13 on: January 03, 2010, 09:04:13 PM »
Not me. I haven't said much (maybe nothing come to think of it) but I've been watching! Please continue!  I've been enjoying the details and learnings.
Logged
Carl (aka Zee. will sometimes respond to 'hey' but never 'hey you'.)
To work. To work.
NickG
Senior Member
Karma 7
Offline Offline
« Reply #14 on: January 04, 2010, 05:10:48 PM »
Nice work Doc, really nice. I like the design of beam engine but the frame puts me off having a go looks too complex for me!
We've just got NX6 at work and the rendering stuff on it is really impressive. You can get photo like models from it now.
Nick
Logged
Pages: [1] 2 3 ... 10   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
TinyPortal v0.9.8 © Bloc
Valid XHTML 1.0! Valid CSS!
Page created in 0.351 seconds with 27 queries.
