Home Model Engine Machinist
September 02, 2010, 09:10:52 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
  Home Help Search Calendar Login Register   *
Recent
[Today at 09:07:06 PM]
[Today at 09:04:46 PM]
[Today at 08:57:45 PM]
[Today at 08:52:47 PM]
[Today at 08:48:59 PM]
[Today at 08:46:43 PM]
[Today at 08:30:56 PM]
[Today at 08:16:51 PM]
[Today at 07:45:45 PM]
[Today at 07:29:38 PM]
Last 5 Shouts:
August 28, 2010, 12:56:10 PM
Duh...I now know how NOT to wire up a cap!!!!
August 28, 2010, 12:55:29 PM
Boy do I know how to let the smoke out....ugh..I give up...
August 20, 2010, 10:47:44 PM
And if you don't know what to look for...then you need some proof of citizenship.
August 19, 2010, 10:25:01 PM
For proof of citizenship...just ask them to supper...and observe.
August 19, 2010, 08:12:30 PM
Wrong family. I'm not worried.
Pages: [1] 2 3 ... 13   Go Down
  Print
Author Topic: Team build  (Read 10724 times)
0 Members and 1 Guest are viewing this topic.
Brass_Machine
Insane Machinist
Global Moderator
Senior Member
Karma 22
Offline Offline
N.J. USA
WWW
« on: March 08, 2008, 12:55:08 PM »
I think that is a great idea Giles.
Some others that have discussed:
1) Team design - a weekend engine maybe?
2) Team build - an engine is picked, people build 1 piece and send it a designated 'builder', assembled. Then maybe sell it on Ebay and donate proceeds either to a charity or to the running of this site.
Eric
Logged
MadModder - Your home for creating, modifying & tinkering (& the tools to do it) fun things!
We're all mad here. I'm mad. You're mad.
rickharris
Senior Member
Karma 9
Offline Offline
« Reply #1 on: March 08, 2008, 03:17:09 PM »
The idea of a team built engine is attractive - working accurately to drawings without the luxury of being able to fit the parts together - Almost like Industry -
Design in UK (OK I am British), Manufacture in India, eastern Europe and China, Sell in USA.
But who would own it after? Donate to a museum?
Logged
I am confused
Bogstandard
Guest
« Reply #2 on: March 08, 2008, 03:40:29 PM »
Rick,
The team built idea is a non starter if there is no interaction between the fitting of parts between members, unless the components can be made to zero tolerances.
Imagine a cylinder being made with 0.002" +- tolerance, and a piston being made to the same tolerances by someone else. High on one, low on another could mean a 0.004" interferance or the opposite dimension could result in a very sloppy fit.
Many parts have to be made for interaction with a close fitting other part.
Giles,
How many to be made in a weekend?
Logged
gilessim
Senior Member
Karma 5
Offline Offline
« Reply #3 on: March 08, 2008, 04:26:11 PM »
John, I didn't say that it had to be done in a weekend, no time limit! and I agree with you about the team build thing, that could be problematic , we would only need someone who wouldn't participate ,to make up a list of materials and off we go!
Giles
Logged
BobWarfield
Senior Member
Karma 16
Offline Offline
WWW
« Reply #4 on: March 08, 2008, 05:26:41 PM »
Rick and John, a couple of principles of the team build:
-  First, each person builds enough copies of their parts so that everyone winds up with all the parts needed to assemble their own engine.  We wouldn't just build enough for one engine.  I have seen cases where additional engines got built too and then auctioned off to provide funds for charity or the club to use.
-  RE precision, you have three choices:
    -  Keep parts that must fit precisely together (i.e. cylinder and piston) are made by the same guy.
    -  Build to sufficient tolerance.  John, it's never zero tolerance, but it may be less than a thousandth sometimes.  Or maybe not.
    -  Build to less than sufficient tolerance and then fine tune immediately before assembly with an additional step.
Making this all work out is part of the fun of a team build!  Having to make more than one part means you can get good at your part, or even build some special purpose fixturing to increase your standards and productivity.
Note that lots of things could be built this way.  For example, if everyone suddenly wanted a KMG clone 2" x 72" belt grinder, or a Quorn Cutter.  Probably best to try it on something simpler to start though!
Another thought is that different folks will have different strengths and weaknesses that ought to be factored into their assignments.  This is based on their skills, interests, and available machinery.  Someone with a CNC mill or lathe can do things others can't.  Someone may have an anodizing rig, so that everyone need not have one.
I'd love to see us do a team build of something fun.  Count me in!  Someone with a good design ought to coordinate.  Lots of guys here with plans.  We need a volunteer.
BW
Logged
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Bernd
Senior Member
Karma 12
Online Online
South of Rochester, New York
WWW
« Reply #5 on: March 09, 2008, 11:17:24 AM »
Great idea Bob.
You said "Build to less than sufficient tolerance and then fine tune immediately before assembly with an additional step."
At work we called this "fit in assmenly" The tolerances that Bogs mentioned wouldn't be a problem to work to. For example a piston would be made to a size of .500" +.005 -.000. The cylinder bore would be made to .500" +/-.002. When the piston arrives at the assmebly point it would be trimmed to fit the bore.
I'd love to be included in this but have that major build to finish: "The House". And the wife isn't letting me forget about it. Sad
Bernd
Logged
You can't fix stupid!
tattoomike68
Senior Member
Karma 7
Offline Offline
« Reply #6 on: March 09, 2008, 02:42:10 PM »
This idea is great, I would be willing to make any part thats all turning. My mill is less than wonderful.
Logged
BobWarfield
Senior Member
Karma 16
Offline Offline
WWW
« Reply #7 on: March 09, 2008, 03:19:29 PM »
Hmmm.  That was very jarring.  Did we really need to split the thread?
Whatever.
BW
Logged
Brass_Machine
Insane Machinist
Global Moderator
Senior Member
Karma 22
Offline Offline
N.J. USA
WWW
« Reply #8 on: March 09, 2008, 07:35:54 PM »
If we are going to do this, and I think we should, a new forum maybe called "Group Builds" or "Board Projects". "Board Projects" is probably better that way it can include other things such as Giles idea of a challenge.
Eric
Logged
Powder keg
Machinist Extraordinaire
Global Moderator
Senior Member
Karma 15
Offline Offline
life is tough, It's even tougher if your stupid:O)
« Reply #9 on: March 09, 2008, 07:54:20 PM »
I'm in. If the engine needs a cast base let me know:o) What kind of engine do we want to build? I think the first one should be fairly simple?
Wes
Logged
Wesley P
Idaho:o)
A Gismo Huh? If it has a flywheel or spins and is made with small parts. I'll take one! If it makes noise, moves, or requires frequent oiling and dusting it's a better deal yet. It's especially right if its shiny and bright.
Brass_Machine
Insane Machinist
Global Moderator
Senior Member
Karma 22
Offline Offline
N.J. USA
WWW
« Reply #10 on: March 09, 2008, 07:58:06 PM »
Wes
Absolutely simple at first. I am thinking maybe a steamer? That way we are not dealing with carbs and ignition at first. Maybe one of Elmers?
Eric
Logged
tattoomike68
Senior Member
Karma 7
Offline Offline
« Reply #11 on: March 09, 2008, 08:16:21 PM »
Eric
Eric if we do what we say we are going to do and build a running engine at that point I will be happy to add a board, till then a sticky thread or two in the "A Work In Progress" will work. :0
I think we have things covered and dont want to add too many boards , if two board serve the same porpose we will just merge the boards later.
See what Rake60 and the others think of that but thanks for the idea. I will keep it in mind.
Logged
Tin Falcon
Senior Member
Karma 26
Offline Offline
Down Jersey, East Coast USA
« Reply #12 on: March 09, 2008, 08:39:57 PM »
As far as plans how about Elmers Scottythere are about a dozen parts and it is two pages one of the plans and one describing the build. The smallest fastener is 2-56. the bore is 3/8. IMHO I would not want to see smaller than this for a team build.The engine is fairly small and would not take a lot of material.
It is a little more interesting that a wobbler but do not think too complex. The fly wheel is spokeless but could be dressed up if desired.
As far as a new sub- forum I agree with Mike lets see if this Idea can be put together and we can get 'er flying before we build a hangar.
Bob :
Did not mean to startle you but believe the team build and the design challenge are both good viable ideas. They are also different enough that each deserves individual attention. Having both tangled together in the same thread IMHO would get confusing.
« Last Edit: March 09, 2008, 08:55:29 PM by Tin Falcon » Logged
Ad maiorem dei gloriam - Ad vitam paramus
Jadecy
Engine of the Month Nominee
Senior Member
Karma 7
Offline Offline
Columbus, Ohio
« Reply #13 on: March 09, 2008, 08:44:01 PM »
I'd like to be included as a "part maker". I will try to keep an eye on the thread.
Logged
Powder keg
Global Moderator
Senior Member
Karma 15
Offline Offline
« Reply #14 on: March 09, 2008, 11:29:54 PM »
I like the poppin:o) Maybe double sized?
Poppin plans
Logged
Wesley P
Idaho:o)
Pages: [1] 2 3 ... 13   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
TinyPortal v0.9.8 © Bloc
Valid XHTML 1.0! Valid CSS!
Page created in 0.171 seconds with 28 queries.
