Home Model Engine Machinist > Building Them > Team Builds > TB3 - Roll Call
Old 07-09-2008, 11:44 AM   #21
Liked 175 Times on 144 Posts
Default Re: TB3 - Roll Call
I didn't see the springs on the parts list. Are we making springs or finding some that are already made?
Old 07-09-2008, 10:56 PM   #22
Forgot about the springs. We'll have to make them also. Anyone want to play with those?
We are still missing page ten. David sent me a link with the plans and it is gone off his page also. I Emailed him and let him know about it.
Wes
Old 07-10-2008, 01:47 AM   #23
chuck foster
i will have the springs on the valves when i'm done............unless someone really wants to make the springs ........just let me know
chuck
the northern chuck
chuck foster is offline
Old 07-10-2008, 09:18 PM   #24
zeusrekning
I attempted to solder a 3/16 carbide endmill to a piece of brass shim stock(.020" thick). It worked very well. I can't solder for $#!^ ,yet. So I'm sure soldering won't be a problem.
Tim
"The superior man is modest in his speech, but exceeds in his actions."
zeusrekning is offline
Old 07-10-2008, 11:55 PM   #25
Ok, David fixed my link and I sent it to all the team players) There is a cam, regulator bobbin, and regulator arm left. Any takers?
Wes
Old 07-11-2008, 04:22 AM   #26
JMe
i take the regulator arm pivot
Jacques
JMe is offline
Old 07-11-2008, 09:42 AM   #27
Dick L.
Wes, I'll do the Bobbins. I didn't see a call out for material type for them though.Needs to be a good bearing surface inside and out. How about cast iron or brass?
Dick
Dick L. is offline
Old 07-12-2008, 11:15 PM   #28
I was just checking to see if Te_gui got my PM about the Flywheels? I haven't heard back yet.
Wes
Old 07-13-2008, 06:22 AM   #29
te_gui
Hey Wes,
I had thought I replied but it may have gone poof, I dunno. We are trying to decide on flywheel material. I have lots of steel available, maybe some brass/bronze but probably not enough to do all of them. If I do steel I am looking into a friend who does nickel plating to see if that might be a feasible option. Enough brass from McMaster Carr will be about 650 so that's a little steep. I think aluminum might be a little light for a hit and miss, they need the mass to carry them thru. Anyone have any thoughts or suggestions?
Brian
te_gui is offline
Old 07-13-2008, 12:40 PM   #30
I plan to paint my flywheels, similar to the pictured version. So steel is fine for me.
Roll Pins? kvom Tips and Tricks 6 08-27-2010 04:19 AM
Moving a 310 lb. Shear/Brake/Roll RobasaurusRex Questions and Answers 11 06-11-2009 01:19 PM
TB2 - Roll Call Brass_Machine Team Builds 0 06-20-2008 05:02 AM
TB1 - Roll call for Elmers OC Brass_Machine Team Builds 0 05-21-2008 06:31 AM
What Would You Call This? rake60 The Break Room 2 08-28-2007 01:12 AM
