Home Model Engine Machinist > Building Them > Team Builds > TB3 - Roll Call
Old 07-07-2008, 02:25 PM   #11
Default Re: TB3 - Roll Call
I got my prints from Chuck. David is getting me the prints. If pages are missing I'll get them out, but I couldn't see anything that wasn't there? I was going to talk to him about serial numbers also)
Wes
Old 07-07-2008, 03:00 PM   #12
Liked 174 Times on 144 Posts
When I read the part about the numbers, I thought he said they would be assigned after each engine is running.
Old 07-07-2008, 03:26 PM   #13
te_gui
I thought I had posted earlier offering to do the flywheels. I don't see that post now, apologize if it shows up twice. What sort of material and how many engines are we building again?
te_gui is offline
Old 07-07-2008, 03:29 PM   #14
Question reading blueprint (HHM1-13):
The pushrod lock nut is a 3/16" brass cube drilled and threaded 6-32. It seems that there should be a round "collar" around one end of the threaded hole around which one end of a spring rests. However the plan states "turn to .235 diameter". Is this a misprint (should be .135), or am I misreading something?
Also, can someone explain why the dimensions on the pushrod bearing are in red?
Old 07-07-2008, 03:49 PM   #15
Brass_Machine
Brass_Machine's Avatar
Liked 31 Times on 55 Posts
+2 to how many team members. So 12 members +2. 1 for each member, 1 for HMEM to display at shows and 1 to sell for website support or charity.
The display model will be available to all members who go to shows.
Eric
madmodder - Mod Central
We're all mad here. I'm mad. You're mad.
A still more glorious dawn awaits...-Carl Sagan
Brass_Machine is offline
Old 07-07-2008, 03:57 PM   #16
Twinsquirrel
Twinsquirrel's Avatar
I think I will be able to tackle the start lever plus something else..... I fancy the carb but I think it may be out of my league, although we do have six months or so....
David
Twinsquirrel is offline
Old 07-07-2008, 04:14 PM   #17
kustomkb
kustomkb's Avatar
Liked 55 Times on 54 Posts
sign me up for the connecting rods. thanks, are the plans uploaded?
edit. sorry didn't read all the previous posts.
-Kevin.
"No charge for the extra weight reduction Eh!"
My Photo's My Video's
kustomkb is offline
Old 07-09-2008, 02:54 AM   #18
joe d
Liked 51 Times on 50 Posts
Wes:
If nobody else is lining up for them, I'll do the points, they look interesting.
Joe
joe d is offline
Old 07-09-2008, 11:17 AM   #19
zeusrekning
Joe, What are your plans on the tungsten contacts for the points? I had looked them over and wondered about 1/8"dia TIG welding electrode. But I'm not sure how that would cut the 100% is super brittle. The 2% thoriated (sp) is not as bad. But if those options do not work I have tons of tungsten scrap at work. I can get a few pieces of. It is 92% pure machines like cast iron. I think the 2% would probably work best but let me know.
Does anyone involved with the team build already have a running IC engine Reason I ask is I built a transistorized ignition a few months back. It worked well on my test engine (junk yard two stroke) but I was never able to test it on an engine known to be a good runner. Problem I had was with high RPM but the carb was shot on the engine. If anyone has any ideas PM me.
Tim
"The superior man is modest in his speech, but exceeds in his actions."
zeusrekning is offline
Old 07-09-2008, 11:43 AM   #20
joe d
Tim
I was figuring to go to the local UAP/NAPA and ask if they stocked them... If you've got access to some raw stock I'd happily work with that! Next question is how it solders, figured on some experimenting to see if soft solder would work, or if it would have to be silver soldered.
Cheers, Joe
joe d is offline
Roll Pins? kvom Tips and Tricks 6 08-27-2010 04:19 AM
Moving a 310 lb. Shear/Brake/Roll RobasaurusRex Questions and Answers 11 06-11-2009 01:19 PM
TB2 - Roll Call Brass_Machine Team Builds 0 06-20-2008 05:02 AM
TB1 - Roll call for Elmers OC Brass_Machine Team Builds 0 05-21-2008 06:31 AM
What Would You Call This? rake60 The Break Room 2 08-28-2007 01:12 AM
