Home Model Engine Machinist > Building Them > Team Builds > TB3 - Roll Call
Old 07-06-2008, 06:51 PM   #1
Default TB3 - Roll Call
Here are the interested parties for the IC build. If you need Plans, Email me or Eric and we'll see you get a copy) If there are certain parts you want or don't want) let us know. Me, I picked the parts, I thought, would be hard. That way I have to work for it. Plus after 14- 15 cranks. They probably won't be as daunting.
Parts left=
1. regulator arm
2. cam
Joe d - Regulator and Pionts
Te_gui - Flywheels
JMe - Gears, Cam slide Bearing, Rocker arm, Pivot, Pin, and regulator arm pivot
Twinsquirrel - Start Lever and carbs
Zuesrekning - Spark plugs and oilers
PowderKeg - Crank shaft's
KustomKB - Piston, pings, wrist pin, and connecting rods
Bretk - Mufflers and fuel tanks
Chuck Foster - Cylinder heads and valves
Dick L. - Cylinder block, liner, and Bobbins
Brass_Machine - Base bottom and base sides, bearing caps, and main bearings
kvom - Push rod, push rod bearing, push rod nut, and cam follower
I'm excited about this one. It will be my first I. C. engine.
Later, Wes
Old 07-06-2008, 08:06 PM   #2
Brass_Machine
Brass_Machine's Avatar
Liked 31 Times on 55 Posts
Default Re: TB3 - Roll Call
Cool. I think I will do the base bottom and side
Eric
Please note: This will be a 6 month build... ETA December 2008.
madmodder - Mod Central
We're all mad here. I'm mad. You're mad.
A still more glorious dawn awaits...-Carl Sagan
Brass_Machine is offline
Old 07-06-2008, 08:09 PM   #3
JMe
I confirm i am interrested with gears and some small brass parts
Jacques
JMe is offline
Old 07-06-2008, 09:08 PM   #4
Dick L.
Wes , You can put me in for the cylinder block and liner.
Dick
Dick L. is offline
Old 07-06-2008, 10:43 PM   #5
Liked 175 Times on 144 Posts
As soon as I get plans I'll pick a part.
...edit...
Looked at the plans; how about the push rod, push rod bearing, and push rod nut?
Old 07-07-2008, 01:27 AM   #6
zeusrekning
I'll take what ever. I think I haven't seen plans. Wes If you get overwhelmer I'd like to try some spark plugs.
Tim
"The superior man is modest in his speech, but exceeds in his actions."
zeusrekning is offline
Old 07-07-2008, 02:12 AM   #7
I added the parts that are left to the top of the page. If I missed any please let me know
Thanks, Wes
Old 07-07-2008, 04:14 AM   #8
joe d
Liked 51 Times on 50 Posts
I'll go for the rocker arm, pivot & pin.
Joe
joe d is offline
Old 07-07-2008, 08:17 AM   #9
JMe
you may add for me :
1. Cam slide Bearing
6. Rocker arm, Pivot, and Pin
I think offer to make flywheels, i have a fine source for continuous casting, but it is too expensive to send so a heavy package (15 USD per wheel !!) from Belgium to US. Price for Belgian Postal service.
Jacques
JMe is offline
Old 07-07-2008, 02:23 PM   #10
joe d
Hi all
is it just me or is there no drawing HHM1-10? I see in the notes that Mr Kerzel likes to have builders get serial numbers from him... should we get a block of sequential numbers for ours, and perhaps add "HMEM TB3 No. ?? of ??" just for the heck of it?
Joe
joe d is offline
Roll Pins? kvom Tips and Tricks 6 08-27-2010 04:19 AM
Moving a 310 lb. Shear/Brake/Roll RobasaurusRex Questions and Answers 11 06-11-2009 01:19 PM
TB2 - Roll Call Brass_Machine Team Builds 0 06-20-2008 05:02 AM
TB1 - Roll call for Elmers OC Brass_Machine Team Builds 0 05-21-2008 06:31 AM
What Would You Call This? rake60 The Break Room 2 08-28-2007 01:12 AM
