Home Model Engine Machinist > Showing Them > A Work In Progress > STEN smg 1/2 scale
Old 02-15-2012, 11:06 PM   #1
IanN
Liked 11 Times on 10 Posts
Default STEN smg 1/2 scale
OK, I'm sorry that I've only just thought of posting this project here - it has been under construction for some time now.
The background:
During his National Service (in the 1940's) my father had an "experience" with a Sten gun. The incident became part of the family folk law and in a rash moment I offered to make a model of the Sten for my father.
The project was well underway - I completed the research and drew the appropriate drawings and had started the actual construction but my father passed away before the model was finished and my work on the task ground to a halt.
I re-discovered the model a little while ago and decided to finish it.
IanN is offline
Old 02-15-2012, 11:09 PM   #2
Default Re: STEN smg 1/2 scale
Hi Ian,
Cool, my friend trades in miniatures....and a well known member here makes some.
What caliper are you modeling? 22?
Old 02-15-2012, 11:23 PM   #3
IanN
Hi Dave,
Legislation in the UK is such that the model is non-functional.
The chamber is 4.5mm and the barrel is drilled through at 2mm diameter (just so I can poke arod down the barrel to dislodge anything that got jammed into the 4.5mm chamber......)
Ian.
IanN is offline
Old 02-15-2012, 11:26 PM   #4
IanN
Hi Dave,
Ian.
IanN is offline
Old 02-15-2012, 11:29 PM   #5
OK
Here in the states it is generally frowned upon....ie illegal...to make a machine gun without a "constructor's license", but you can get the paperwork sorted and do so.
I'm very interested in this project...I'll be watching along....but you have piqued my interest about your father and his run in!...
Welcome!
Old 02-16-2012, 12:04 AM   #6
That looks to be a neat little memento to be passed down. It looks like you've got a pretty good grip on it, but if you need anything from drawings, I can probably scratch some up.
Old 02-16-2012, 12:34 AM   #7
Stan
Liked 29 Times on 29 Posts
The Sten gun was a classic example of 'you get what you pay for'.
They cost less than $3.00 to produce during WWII.
Stan is offline
Old 02-16-2012, 08:20 PM   #8
IanN
Some more pictures of the Sten.
The magazine collar.
IanN is offline
Old 02-16-2012, 08:33 PM   #9
IanN
The casing assembly and the casing with the barrel.
IanN is offline
Old 02-16-2012, 08:52 PM   #10
IanN
The bolt and bolt handle
IanN is offline
1/4 scale V8, first project. keith5700 A Work In Progress 365 11-23-2013 12:29 PM
1/6 scale Chevy V8 mklotz Photos and Videos 23 02-17-2013 05:34 PM
1/10 SCALE V8 schmetty A Work In Progress 5 08-05-2011 08:00 AM
Digital Z scale Noitoen Machine Modifications 11 01-04-2010 08:36 PM
Scale Hardware is the U.S.'s best source for scale model fasteners. PTsideshow Links 21 05-21-2008 12:57 PM
