Home Model Engine Machinist > Showing Them > A Work In Progress > Moriya Stirling Fan - Double size
Old 03-21-2012, 12:24 AM   #1
David Morrow
Liked 37 Times on 22 Posts
Default Moriya Stirling Fan - Double size
The short version of a long story is that after having built one Moriya ( a variant, really ), I wanted to repeat the experience without building the same thing. So double size it is. I'll post the pic's here and a brief description. For a bit more detail, you can have a look at the build page here :
http://www.ldrider.ca/cnc/moriya-double/moriya-double-1.htm
The material for this thing, at least the material for the base and the displacer cylinder are awfully big for my little Sherline CNC mill and Myford S7 lathe.
I cut the 1" thick slab of aluminum down to size first on the band saw.
Next, I printed and glued the cad drawing to the work piece. For more complex jobs this really helps ensure everything gets done and in the right order.
The bulk of the displacer hole gets cut out with a hole saw. This takes all of 2-3 minutes on the drill press and means much easy job for the light mill.
Being so thick, I don't like to commit to milling down 1 inch as part of a single operation. So, I break it up into smaller jobs of about .250" - .350" at a time.
I got a bit ahead of myself in the beginning. A sneak preview... but it's a secret so do tell and don't ask.
David Morrow is offline
Old 03-25-2012, 03:34 AM   #2
David Morrow
Default Re: Moriya Stirling Fan - Double size
Base is cut out and partially drilled. First sub-assembly mounted.
Old 03-25-2012, 12:36 PM   #3
GailInNM
GailInNM's Avatar
Liked 189 Times on 159 Posts
Likes Given: 34
Looks good David.
Moriya is one of my favorite engines.
Gail in NM
Gail in New Mexico, USA
I would like to be the kind of person my dog thinks I am.
GailInNM is online now
Old 03-29-2012, 01:24 AM   #4
David Morrow
A bit of progress over the past couple of days.
One big lump of aluminum reduced to a smaller lump of aluminum.
That was exhausting...
Old 04-02-2012, 05:57 AM   #5
David Morrow
For a variety of reasons, I made the cold end cap square but I don't know if I like it yet. I can rework it so that it's round but I'll wait until the rest of the fan is mostly finished to see how it all fits in esthetically.
Power cylinder is now started. It'll be about 2" O.D. x 4" long
Old 04-02-2012, 10:53 AM   #6
lazylathe
lazylathe's Avatar
Liked 24 Times on 24 Posts
Send a message via MSN to lazylathe
That looks great David!
Will be an excellent Stirling fan once completed!!
Nice and big and purposeful!!!
Andrew
The best part about procrastination is that you are never bored, because you have all kinds of things that you should be doing.
Time is money, money is the root of all evil, and knowledge is power. Therefore, procrastination is the key to world peace.
lazylathe is offline
Old 04-02-2012, 03:21 PM   #7
kustomkb
kustomkb's Avatar
Liked 55 Times on 54 Posts
Very nice work!
I have the Moriya book too. One day...
Thanks for the inspiration.
-Kevin.
"No charge for the extra weight reduction Eh!"
My Photo's My Video's
kustomkb is offline
Old 04-05-2012, 05:00 AM   #8
David Morrow
Due to the large diameter of the brass needed to properly scale up the power cylinder, I minimized it and made a retainer to secure it to the base instead.
Old 04-07-2012, 04:10 AM   #9
David Morrow
I decided that the square cap on the cold end just didn't quite work esthetically so I turned it down on the lathe.
Old 04-09-2012, 05:39 AM   #10
David Morrow
Crank brackets cut but with a bit of finishing work remaining. My eyes continue to have difficulty trying to get a handle on the relative proportion of some of the parts but I have no doubt that they are correct.
Moriya Stirling Fan variant David Morrow A Work In Progress 16 10-28-2012 06:37 PM
Double Double (Quad) Scotch Engine flyingtractors1 Finished Projects 4 12-27-2011 01:35 AM
Moriya Stirling Fan build techonehundred A Work In Progress 14 12-31-2010 04:21 AM
Hasbrouck Engine #6 - Double Size Kermit A Work In Progress 11 03-22-2010 05:03 PM
Moriya Build IronHorse A Work In Progress 27 01-12-2009 04:55 PM
