Home Model Engine Machinist > Showing Them > A Work In Progress > Converting a gas engine to steam
Old 06-29-2008, 08:23 PM   #1
rangerssteamtoys
Default Converting a gas engine to steam
Well, I screwed up I broke a valve tappet on my 2 hp briggs. I'm not sure If I want to replace it but in the mean time I have this
Its a 5 Hp Briggs & Straton gas engine, it came off an old generator that quit working. The problem was with the engine, the intake valve was stuck, I fixed that though.
The the cam is already timed for 1 intake and 1 exhaust. A little fine tuning will help though, but now I have to add 2 additional lobes exactly opposite of the other 2 lobes. I would like someone to machine them, but will probably end up welding them.
Ok, the 2 lobes needed: Would anyone like to machine them for me? I will pay you of course, but I just need 2 little lobes machined so I can weld them to the cam.
Hope everyone takes an interest in this, its an easy way to build a steam engine.
Cedge, did you recieve my PM?
Best Regards, Ranger Moore
rangerssteamtoys is offline
Old 06-29-2008, 09:58 PM   #2
Cedge
Cedge's Avatar
Liked 49 Times on 49 Posts
Default Re: Converting a gas engine to steam
Ranger
I'm afraid cutting cam lobes is something I've got no experience with, at all. I'd be quite happy to do it, if I knew more about the process, but I'm lost on this one little dude.
Steve
You are invited to visit the Steam Engine Gallery
Images Removed in Protest of Current Forum Copyright Policies
Cedge is offline
Old 06-30-2008, 12:46 AM   #3
rangerssteamtoys
Ok, Thanks.
I hope another fourm member in the lower 48 will take the challenge. I might just have to take my last resort to welding.
Old 06-30-2008, 12:56 AM   #4
ksouers
Liked 54 Times on 54 Posts
Ranger,
You could build up the lobe with the welder then profile it with a file. Good learning experience.
Mostly you'll learn you don't want to file anything anymore.
Seriously though, filing it won't be that bad if you use a soft grade of metal to build up the lobe. And it'll make you a better welder. You don't want to add any more metal than you're willing to file off.
Kevin
I make things.
ksouers is offline
Old 07-01-2008, 11:13 AM   #5
rangerssteamtoys
Looks like I'm going to weld the lobes on myself. I need to practice welding first, I have some round bar that I can make lobes on.
Hopefully I will get the intake lobe done today. Pictures will follow at the end of the day.
Old 07-05-2008, 04:51 PM   #6
rangerssteamtoys
I welded the lobes on Thrusday. I used a little lincoln MIG welder, after careful grinding and trial and error, it works.
I can get about 500 RPM on about 40-50psi of air, after that the air pushes open the valve and it doesnt work as well. This 5hp engine probably devlops about 1hp on air, or I hope it does.
Video uploading.
Old 07-05-2008, 05:15 PM   #7
rangerssteamtoys
Just take my advice, listen to the voice in the video. Whenever I say, I'm going to start it up......well turn down the volume then. When engine stops listen to voice then turn down volume
This engine is LOUD
http://www.youtube.com/v/JxaVER4U6d4&hl=en&fs=1
I'm running this engine on about 40-50 psi of air. I get about 500 RPM. After you cross about 50 psi the valve opens on the intake and the engine doesnt run as good.
Old 07-05-2008, 05:26 PM   #8
Twinsquirrel
Twinsquirrel's Avatar
Nice project Ranger, I've been following with interest, you have a lot of focus!!!
Twinsquirrel is offline
Old 07-05-2008, 05:51 PM   #9
Well done Ranger!
Old 07-05-2008, 05:53 PM   #10
Looks like you are having fun) I built an air compressor out of a 5 hp Briggs. It worked great for a few years.
Wes
Converting PDF to cad(ALIBRE) crankshafter Questions and Answers 17 04-08-2014 05:16 PM
Converting my shop, again Blogwitch The Shop 17 04-17-2012 12:16 PM
Converting a 4 stroke motor to a Hit and Miss engine steamertate Plans 2 04-09-2012 04:59 PM
Converting a Sieg X1 lensman57 CNC Machines and Conversions 16 10-24-2011 12:58 AM
Converting a Super Stirling fan Boot Questions and Answers 10 12-17-2009 12:25 AM
