Home Model Engine Machinist > Showing Them > A Work In Progress > 3 cylinder radial
Old 04-27-2011, 12:00 AM   #1
TuxMan
TuxMan's Avatar
Liked 14 Times on 14 Posts
Default 3 cylinder radial
It is the time for the next project. This time I have selected the Potty three cylinder air engine. Plans can be found on this site.
I will be making some relatively minor changes to the original design including not using metric screws. I have modeled all of the parts and produced new drawings with inch dimensions. I find it less error prone if I do not need to do the translation from mm to inches on the fly.
I ordered the material I needed and started making chips just over a week ago. I will now try to get this build log up to date.
I started with the largest piece in this engine, the crank case. Starting with a 2.5 inch diameter piece of aluminum I turned a section down to 2.1 inches to reduce the amount of milling. I also bored out the central cavity. I used my 4-jaw since my 3 jaw is on the small size and would not grip as well as the 4-jaw.
Next I move the chuck with the part to the h/v rotary table on the mill. After milling the hex shape I drilled and tapped all of the holes on the hex faces.
Then it was back to the lathe where I parted the crank case from its handle. Back on the rotary table, this time in the horizontal position with the 3-jaw I milled the part to length and did all of the features on the valve face.
After drilling and tapping the holes on the bearing housing face and a little cleanup I had my firs finished part.
To be continued
Eric
TuxMan is offline
Old 04-27-2011, 12:23 AM   #2
TuxMan
TuxMan's Avatar
Default Re: 3 cylinder radial
Next the bearing housing. This time I started with a 2 inch diameter piece and turned the mounting flange and the boss the fits inside the crank case. I also drilled and bored the bearing recesses.
After drilling the screw clearance holes I made a simple arbor by turning a 1 inch steel rod for a slip fit in the .875" bearing recesses. Drilled a deep tap drill hole with a shallow clearance hole for a 1/4-20 bolt and parted off a thick washer. After tapping the part still in the chuck I could mount the bearing housing and face to length and turn the taper..
Next I worked on the cast iron pistons. This was my first time machining cast iron and it went smoother than I anticipated. First I turned the outer diameter and the groves. Next I used a .375 end mill to "drill" the flat bottomed hole in the bottom of the piston. I finished by flaring the bottom of the piston. I cut the piston from the stock and face it to length. Repeat 3 more times as I wanted an "insurance" piece.
On the mill I drilled and reamed the .125 wrist pin hole in each piston.
To cut the cut the square pocked in the piston I used a .125" rod and a 1-2-3 block to get the wrist pin hole parallel with the mills Y axis. I then used a .375" pin to locate the center of the piston. A few passes around the .375 diameter hole mad it a .375 square with round corners. When I was done I had 4 usable pistons.
I also made the cast iron cylinder liners, No pictures, just simple turning and boring.
I could not resist attaching the bearing housing to the crank case to see how they looked. Here is a photo of the progress to date.
I am now up to date,
Thanks for checking in
Eric
TuxMan is offline
Old 04-27-2011, 01:17 AM   #3
nfk
Bottom Member
Send a message via ICQ to nfk
Great start Eric!
Keep the pics and comments coming, i will enjoy this thread for sure.
Norberto
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
nfk is offline
Old 04-27-2011, 02:42 AM   #4
dsquire
dsquire's Avatar
Liked 30 Times on 27 Posts
Eric
You have made a great start on this engine. I will be watching as you progress with it as will be many others I'm sure. Keep up the fine work.
Don
Good, better, best.
Never let it rest,
'til your good is better,
and your better best
dsquire is offline
Old 04-27-2011, 05:03 AM   #5
SBWHART
SBWHART's Avatar
Liked 161 Times on 149 Posts
Very nicly done and shown Eric
Look forward to the next instalment.
Stew
A little bit of clearance never got in the way
SBWHART is offline
Old 05-01-2011, 10:00 PM   #6
TuxMan
TuxMan's Avatar
Norberto, Don and Stew
Thanks for checking in and for your kind words.
Stew, also thanks for the plans that are the basis of this build.
I got a bit more done on the engine this week. I started on the cylinders. The smallest stock I had that could be used for the cylinders was 2 inch round rod. A bit large but it will work. I started by cutting 3 pieces about 1.25 inches long and then mad lots of chips. I milled the 1 and 1-3/8 dimensions about .025" over sized. This way if I am a little off on the bore it will be OK.
After drilling the center of the bore with the DRO on the mill I went to the lathe and drilled .625" diameter and bored to .750 inches.
Next I modified the arbor that I made for the bearing housing. I turned it to a close fit on the cylinder bores with a length of approximately 1 inch. I made a slight undercut so that the inside radius does not cause any problem. The thick washer was unchanged.
After a detour to make a better parting tool holder I turned down the 1 inch diameter. I will not be making the simulated fins since I do not ave a suitable tool.
This is it for another week.
Eric
TuxMan is offline
Old 05-02-2011, 05:51 AM   #7
SBWHART
SBWHART's Avatar
Looking good Eric,
I made the tool to cut the fins from a small bit of HSS they only need to be a scratch deep, Another good source for thin grooving tools are broken hacksaw blades with a suitable holder.
Stew
SBWHART is offline
Old 05-08-2011, 08:45 PM   #8
TuxMan
TuxMan's Avatar
This weeks update on the build progress.
I had limited shop time this week but did get to nearly finish the cylinders. Based on Stews comments, Thanks Stew, I made up a tool to cut the fines. I used a .125" diameter center drill that the tips had been broken off to grind a .060" wide tool. I made a simple holder from a 1/2" square piece of steel to told the tool and used it to cut the fins as shown below.The other end of the center drill was ground to use to face the inside of the flanges.
I still need to round the corners of the flanges but that will wait until I have the cylinder heads finished so that they can be done together. Here are the nearly finished cylinders.
Eric
TuxMan is offline
Old 05-08-2011, 09:04 PM   #9
SBWHART
SBWHART's Avatar
If you blacken the fins with a sharpy and gently clean the tops off with fine emery the grooves will remain black making them look deeper.
Fine work Eric
Stew
SBWHART is offline
Old 05-11-2011, 03:23 AM   #10
Brass_Machine
Brass_Machine's Avatar
Liked 31 Times on 55 Posts
Nice job! I like.
Eric
madmodder - Mod Central
We're all mad here. I'm mad. You're mad.
A still more glorious dawn awaits...-Carl Sagan
Brass_Machine is offline
1/6 scale 9 cylinder radial build ninefinger A Work In Progress 9 05-14-2013 11:49 AM
6 Cylinder Radial Engine. Rocket Man Finished Projects 13 04-07-2012 04:36 PM
Three cylinder Radial Russel A Work In Progress 60 11-01-2011 01:19 AM
three cylinder radial engine dparker Photos and Videos 3 09-06-2008 09:31 PM
Anzani 3 cylinder radial drawings cfellows Questions and Answers 4 08-03-2008 05:58 PM
