Home Model Engine Machinist > The Tools and Tips > Machine Modifications > what belt?
Old 07-20-2012, 02:27 AM   #1
blighty
Liked 14 Times on 14 Posts
Default what belt?
i have owned an RF45 for 3 odd years now and my ears can't take them ruddy gears any more. so for the sake of my hearing i think it's time for a belt mod.
but what sort?
i have seen many types of belts being used..... apart from one.... the common V belt. there is probably a reason for this, but i cant figure it out what that may be. it might have something to do with efficiency. but saying that, Bridge Ports and such other milling machines have been using V belts for years and they seem to do all right.
at the mo i can think of three belt options.
1 V belt
2 toothed belt (5mm pitch)
3 poly V belt.
i would like to go with the poly belt, but at the mo i can't find a place on the net (UK) that sells them in X length. toothed belt would be the next one and the V belt would be the easiest as the pulleys are not that hard to make.
any ideas/ thoughts?
blighty is offline
Old 07-20-2012, 11:35 PM   #2
like you said bridgeports use V-belts and the little x-2 pulley conversions use v belts.
Old 07-27-2012, 03:23 AM   #3
terrywerm
Keeper of the Coffee Pot
terrywerm's Avatar
Liked 44 Times on 30 Posts
Likes Given: 9
A few other points to consider: timing belts will make some noise, especially at higher speeds. As a rule, V belts will run more quietly and they are available just about anywhere.
Terry
Making chips with old machines. There's nothing like it!
terrywerm is offline
Old 07-27-2012, 06:11 AM   #4
velocette
Liked 15 Times on 12 Posts
Hi My sypathy with battered ear syndrome I have converted my X2 mill to belt drive.
Much more peacefull now.
I have had a quick look at the specs for a RF 45 mill a very nice peice of machinery
One question springs to mind Have you changed the oil in the gearbox since new as some times the original oil leaves a lot to be desired.
Have you considered fitting a DC variable speed drive as single phase AC motors do run roughly.
I did this conversion on 10 X 27 lathe and the drop in noise level was very notable.
To improve even more fitted an oil pump to deliver oil to a gallery
in the gearbox lid to flood all the gears and bearings with about a half litre a minute of oil.
Check this link it was a great help
http://www.homemodelenginemachinist.com/f16/single-phase-motor-chatter-17383/
you may want to do more research into a belt conversion
This is my attempt on an X2
http://www.homemodelenginemachinist.com/f28/x-2-mill-belt-drive-alternative-15157/
Keep us all posted please
Eric
velocette is offline
Old 07-27-2012, 07:50 AM   #5
chipenter
I have been using
polly V belts for some time now , made pulleys and find they are much easer to change and quiet , the pulley were simple to make to .
http://www.solenttools.co.uk/p0/poly-v-drive-belts/363050.htm UK supplier .
chipenter is offline
Old 07-27-2012, 05:17 PM   #6
blighty
velocette....
yep, the oil was changed out about 9 months a go. i rang the guys where i got it from and they even said "don't use the oil recommended, use this stuff" can't remember what "stuff" was exactly, but it did quieten it down from the noise of really big tank to the noise of a big tank.
motor wise....
i nice new 2.2kw 1400rpm 3phase motor turned up last week and yesterday the VFD turned up to run it. with the gear ratios i have chosen should give me 445rpm/ 1100rpm and 2150rpm/5000rpm. as you can see i have a gap in the middle of 1000rpm that i can't get with just 2 gears. that why i thought of v belts, so i can get another gear in the with the amount of space i have.
but now with chipenter link (thx) i might change my mind about the v belts and go with poly......
chipenter...
how wide are you poly v belts? as this will help my a lot in deciding on how many gear ratios i can have.
thx for all your input gents
blighty is offline
Old 07-27-2012, 08:20 PM   #7
velocette
That is another alternative to variable speed as a three phase motor will run much more smoothly than single phase.
PJ Poly Vee belts are 2.34 mm per rib X 6 ribs + 1 rib 16.98 plus lands
Say 20mm wide pulleys. The belt width is only approximate for the 2.2 kw motor.
As you will appreciate That the bigger the diameter of the pulleys the less
the loading on the belt.
Keep us posted with pictures too for being a NUT on conversions and modifications get great pleasure in seeing how other tackle them
Found this surfing not sure if this is the same as your mill
http://www.cnccookbook.com/CCMillBeltDrive.html
It may help
Eric
Old 07-28-2012, 12:44 AM   #8
ninefinger
ninefinger's Avatar
Liked 20 Times on 17 Posts
I too feel your ear drum pain as I have an MD-001 (the slightly bigger brother to the RF-45 otherwise known as an Industrial Hobbies mill clone). I have been looking at how a few other have done this on other forums and the ones that look the nicest have been done with the poly vee belts. Typical is 2 sets of pulleys with a high range and a low range, usually giving up a fair amount of low end torque over the gears in favor of much higher top end (typically 2x original), with a big 3 phase motor and VFD.
I "think" that the reason plain old V belts aren't used is to do with the pulley size. If you want to keep things compact (ie in the original head envelope) then you need to use small diameter pulleys. That in turn means a smaller cross section V belt and lower overall power transfer. The poly vee belts are better in this respect (pulley size to power transfer) and also require less pulley movement to effectuate a change of ratios versus the deep groove of a v belt.
Do please keep us informed of your choice - I may one day get off my duff and do something about the noise and when I do I want to be able to copy somebody, not blaze a trail...
Mike
ninefinger is offline
Old 07-28-2012, 07:14 AM   #9
chipenter
I had two belts over 30 mm wide so turned them inside out, and cut them into 4 grooved belts with a Stanley knife ,made the pulleys with 12mm wide steps .
Old 07-30-2012, 02:02 AM   #10
blighty
chipenter.....
just been look at that web site for the poly belt. seems strange that all types of poly belts are out of stock. i'll give them a buzz when the time comes.
velocette...
"PJ Poly Vee belts are 2.34 mm per rib X 6 ribs + 1 rib 16.98 plus lands"
if you have a look here http://www.solenttools.co.uk/p0/poly-v-drive-belts/363050.htm their a bit lite on info about there belt's, you just buy them by how many groves you want. do you think it would be the same dimensions you gave above?
if that is the case then 7 or 8 grove belt will do for me. plus i can get three pulleys/gears in the amount of space i have.
blighty is offline
Help me identify this belt? radfordc Questions and Answers 7 06-17-2011 09:31 PM
MXL Belt stevehuckss396 Questions and Answers 8 05-01-2010 01:18 PM
Drill press belt wes Special Materials 8 04-06-2010 10:15 PM
Miniature fan belt stevehuckss396 Questions and Answers 18 01-09-2009 09:23 PM
Belt Sander Stan Tools 3 02-14-2008 07:21 PM
