Home Model Engine Machinist > The Tools and Tips > Machine Modifications > ONE SHOT OILER
Old 03-02-2012, 01:07 AM   #11
dieselpilot
Liked 80 Times on 73 Posts
Default Re: ONE SHOT OILER
Ron, I think the size only matters relative to how much you want each one to flow. The volume will be whatever you pump into them. The distribution is depended on the resistance as you said. If each valve is the same, each location will get the same amount of oil. The question is how much oil does each location really need?
http://www.cnccookbook.com/CCMilllOneShot.htm
These people make the right parts.
http://www.bijur-lubrication.com
dieselpilot is offline
Old 03-02-2012, 04:25 AM   #12
1Kenny
Liked 11 Times on 11 Posts
The one shot on mine oils the ways and screws, it is a hand pump. It has a Bijur pump on the back used for misting. I don't use the main pump as flooding is too messy.
Kenny
1Kenny is offline
Old 04-06-2012, 05:11 PM   #13
platypus20
platypus20's Avatar
I put a one shot system on my 1938 Bridgeport milling machine, I bought the Enco pump, then made the orifices based on the size for the new milling machines. I threaded the elbow fitting and put an aluminum set screw in the fittings, the drilled the set screws to the needed sizes, then check the flows to approx the same flow out of each of the fittings.
Price, Quality, Delivery pick any two
platypus20 is offline
Old 04-10-2012, 04:53 PM   #14
Swede
Liked 27 Times on 27 Posts
Platypus - kudos on a truly nice installation. The pride you've taken in your work is obvious.
Swede is offline
Old 04-10-2012, 07:40 PM   #15
d.bick
When I restored my Bridgeport I had the idea that I could clean the original old metering valves. What I found when I took one to bits is they have their own filter the metering is achieved by the oil travelling round a thread and through a one way valve.
I replaced all the valves and the pump with the Arceurotrade(U.K. items
d.bick is offline
My first shot at scraping TroyO Machine Modifications 13 07-03-2012 02:31 AM
OILER CUP ZAPJACK Finished Projects 5 11-29-2010 05:49 AM
Parting shot SignalFailure Safety 7 11-15-2010 05:55 AM
IH Mill Prep for CNC Conversion: One shot oiler, Z-mod, etc. BobWarfield Machine Modifications 30 11-05-2008 06:25 PM
Screen shot Powder keg Computer Geek Zone 5 02-06-2008 03:33 AM
