Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Electronic leadscrew for my lathe
Old 01-16-2011, 11:10 AM   #1
picclock
Liked 17 Times on 17 Posts
Default Electronic leadscrew for my lathe
Not sure if this is the correct place for this, but its new and I made so here goes.
This was born out of the frustration of trying to accurately turn parts consistently, and the fact that the slowest leadscrew speed was far too fast for my needs. The speed of traverse on this can be set to < 30 thou per minute.
Hope its of interest.
with additional pictures at
http://s917.photobucket.com/albums/ad19/picclock/Cheapo%20Electronic%20Leadscrew/
Some rough design notes are in the download section. If you need any further info I'll do my best to oblige.
picclock
From Ashtead, Surrey, United Kingdom
Dedicated to the art of efficiently transforming large useful pieces of metal into ever smaller pieces of scrap.
picclock is offline
grahamA Likes This
Old 01-16-2011, 12:50 PM   #2
ttrikalin
Default Re: Electronic leadscrew for my lathe
enjoyed it?
loooooved it!
very neat idea!
best
tom in MA
tom in MA, US
http://web.me.com/ttrikalin/toms_corner/Home.html
ttrikalin is offline
Old 01-17-2011, 04:11 PM   #3
chalky
Hello all, This subject is of great interest to me but having refered to Picclocks brief notes, not written in" metalstrangler " is thus a total non understand for me.
The product is great and raises questions -
1. does the PIC have the capacity to do other things ,for example operate a rotary table to divide a circle into a predetermined no of parts for gear cutting?
2. Could the unit be used to control the rotary movement of a cutter in a tool & cutter grinder to follow the lateral movement of the cutter holder.(follow the helix of the cutting edge) .This I find to be a great problem in sharpening small end mills.
Thanks for your time. chalky.
chalky is offline
Old 01-18-2011, 01:30 PM   #4
joegib
Originally Posted by chalky
1. does the PIC have the capacity to do other things, for example operate a rotary table to divide a circle into a predetermined no of parts for gear cutting?
I don't know how adaptable picclock's interesting interesting project is to the jobs you've queried — maybe he'll comment on that in due course. You might like to know, though, that there's that there's a mature and reasonably cheap electronic controller project for dividing heads/rotary tables on the CNCZone site. It's designed by 'Kwackers' and fully described here:
http://www.cnczone.com/forums/open_source_controller_boards/47007-rotary_table_indexer.html
Joe
London, UK
joegib is offline
Old 01-19-2011, 11:06 AM   #5
chalky
joegib, many many thanks for the lead to cnc forum you posted. I have spent hours allready reading the thread. What a contributor "Kwackers" is !!!
chalky.
chalky is offline
Old 01-19-2011, 04:02 PM   #6
picclock
@ chalky
I'm afraid the pic on this project is pretty well tapped out, multitasking caliper reading, button presses, motor pulses, display updates, calculating acceleration/deceleration etc.
I would suggest that if you want a rotary table divider (don't we all ) then kwackers one or a kit that Bogs tested (can't remember name) would be a good way to go.
When I started it was just going to be a simple pulse generator for a stepper motor but it sort of mushroomed as I added more and more features.
If I'd had an idea of where I'd end up I'd have included the programming and motor drive for the crosslide
It is turning out to be very useful and a great timesaver when turning large diameter parts at the slow fpm they need.
For me, when I get time, I will make a multiple remote DRO readout for my mill cos I'm to cheap to buy one .. . (and the cost of the batteries )
Sorry about time to reply but I haven't been able to log on to HMEM for some days.
picclock
picclock is offline
Old 01-20-2011, 10:32 AM   #7
chalky
Mr Picclock sir.
Far from being delayed your speed of very helpfull reply is much appreciated.
The list of hoped for applications was realy only a list of the activities that I find tedious or difficult in my old age.
Many thanks for your input to a truly instructive and enjoyable thread.
chalky,
chalky is offline
Old 01-20-2011, 02:03 PM   #8
picclock
@ chalky
If I remember correctly kwackers project uses a pc, whereas the one Bogs tested was a self contained stand alone unit.
(Edit : clearly remembered incorrectly - kwackers unit is stand alone)
best regards
picclock
picclock is offline
Old 01-21-2011, 06:25 AM   #9
joegib
No, the Kwackers project is for a standalone, boxed controller independent of a PC just like the Division Master.
Here's a link to a build described over on the Madmodders site by 'craynerd':
http://madmodder.net/index.php?topic=2242.0
Here's a U-Tube video outlining a build by M. Parker-Lisberg:
Joe
London, UK
joegib is offline
Old 01-21-2011, 07:09 AM   #10
picclock
@ Joe - That's a great video of kwackers project . I must have it mixed up with another rotary table project.
I have the 6" rotary table shown in the video, but don't use it enough (yet) to justify a controller like that. I avoid using mine if possible because of the difficulty of accurately aligning it to the spindle, and then accurately clamping the work to it. It makes me seriously envy those guys who go CNC.
Thanks for correcting my mis-information.
picclock
picclock is offline
leadscrew project - power transmission question Sshire Questions and Answers 15 06-06-2012 03:45 PM
Externally powered leadscrew project Sshire Finished Projects 2 06-06-2012 11:27 AM
Sieg x1 LeadScrew Flange lensman57 Questions and Answers 0 09-26-2011 12:33 AM
MOVED: Electronic leadscrew for my lathe Maryak Finished Projects 0 01-16-2011 08:38 PM
Leadscrew Handle SKIPRAT Machine Modifications 5 11-22-2009 09:17 PM
