Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Belt drive conversion on 550w mini mill
Old 06-17-2010, 09:45 AM   #1
don-tucker
don-tucker's Avatar
Liked 89 Times on 55 Posts
Likes Given: 20
Default Belt drive conversion on 550w mini mill
Thinking about the belt conv,on my mill,wifey doesn't like the noise.I have looked at the commercial one and have plans to make my own,but seems a lot of hassle getting materials etc,is there a supplier of a kit in the UK.
Don
don-tucker is offline
Old 06-17-2010, 12:00 PM   #2
HS93
HS93's Avatar
Default Re: Belt drive conversion on 550w mini mill
RGD tools prob have some pulleys that will do you what model mill is it ? X1 X2 X3 ?
Peter
how big a hammer do I need ?
HS93 is offline
Old 06-17-2010, 05:14 PM   #3
don-tucker
don-tucker's Avatar
Likes Given: 20
Hi Peter,it is the X2 with larger motor and longer table ,sold by Warco.
Don
Old 06-18-2010, 01:37 PM   #4
don-tucker
don-tucker's Avatar
Likes Given: 20
That's all sorted thanks to a kind member who put me in touch with someone who had most of the bits,pulleys,belt and motor plate for sale.
I should have them tomorrow morning.
Don
Old 06-26-2010, 02:57 PM   #5
don-tucker
don-tucker's Avatar
Likes Given: 20
Well that died a death,the bits were no use as with the larger motor everything is different,had my money back on good old e-bay.
Thought I would mention it in case someone else has the same idea,I shall give my misses a pair of ear plugs untill I have the time to make something up.
Don
Old 06-30-2010, 03:41 PM   #6
Lykle
Liked 7 Times on 6 Posts
Hi,
I have converted my mill myself.
Was not to hard to do. If you want my plans, just tell me. Oh why bother. I'll attach them for you.
They are metric, and for a Real Bull X2, which has its control box in a different location then the "normal" ones.
Lykle
Lykle is offline
Old 06-30-2010, 04:03 PM   #7
don-tucker
don-tucker's Avatar
Likes Given: 20
Thanks very much for that Lykle.
Don
Old 09-28-2010, 04:49 PM   #8
Corvus corax
Sorry for the thread bump.
I have an Einhell MBF550 which is also a 550 Watt Mini mill and I suspect similar. As of yet I haven't broken the plastic gears but I would like to do some fly cutting and from what I have read that will end in tears.
I have heard repeatedly that the kit from LMS won't fit the Einhell so I suppose I will have to make my own.
It's great to see some metric plans! Can I just ask the following:
What angle are those V pulleys and what belt was used in the conversion?
Corvus corax is offline
Old 09-28-2010, 06:51 PM   #9
Anko
Entusiasta
Liked 63 Times on 38 Posts
Send a message via MSN to Anko
I too own a Einhell mini mill
i have done the belt-drive myselft, not too hard to do, i based my desing in the LMS common design
but have to move the circuit box a little to make room for the bottom plate, doing this there is no more room for the torsion spring arm so I done the air spring mod simultaneously
I dont remember well..the slower speed was arround 2000 RPM and the higher 4000 RMPS
The belt i bougth from LMS is a Truflex 0130, the angle cant remember either, but i measure it directly from the belt in my hand and a protactor jajaja
now im planning to change the beltdrive for some other drive design that allow me to have more torque, reducing the spindle speed to ranges like hi-torque 0-500 rpm, normal-torque 0-1000 rpm and high-speed 0-2000 rpms
but thats ir more future from now
anyway Corvus how long habe you owned the Einhell mini mill?
i wish to comparate my mini mill with some other of the same kind, to see if the problems that have showed mine are common or just i got bad luck jajaj
Saludos
Anko is offline
Old 09-28-2010, 07:54 PM   #10
tel
tel's Avatar
Liked 105 Times on 101 Posts
I had tro space out the control box exactly the same as that Anko, as the plate fouled it otherwise. Here are the parts for mine in, roughly, their working position relative to each other. A very simple project really.
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
X 2 Mill Belt Drive Alternative velocette Machine Modifications 2 09-08-2012 05:03 AM
Fitting belt drive to an X2 mill tmuir Machine Modifications 18 07-27-2012 06:24 AM
Mini Mill Belt Conversion Kanuck1958 Machine Modifications 7 04-25-2011 11:04 AM
Help - X2 Mini Mill Plastic Drive Gear Auzzie53 Machine Modifications 7 03-17-2011 08:47 AM
VFD and Belt Drive Mod for the X3 Mill cba Machine Modifications 1 10-19-2010 11:10 AM
