Home Model Engine Machinist > Building Them > Questions and Answers > Turning Between Centres
Old 11-08-2008, 08:33 PM   #1
Default Turning Between Centres
Hi Guys,
I've noticed in a couple of posts that when turning between centres, the soft centre is held in a 3 jaw chuck.
I've not seen it done that way before.
Please, why is it done this way
Old 11-08-2008, 09:14 PM   #2
Liked 174 Times on 144 Posts
Default Re: Turning Between Centres
I think you saw my posts.
The shop doesn't have the slotted dog plates handy AFAIK. The jaws work just fine given that the leg of the dog is long enough for contact.
Old 11-08-2008, 09:40 PM   #3
Liked 2273 Times on 2034 Posts
Maryak--The biggest reason is that it saves me the agravation of having to remove the chuck and install the faceplate.
Old 11-08-2008, 09:54 PM   #4
kvom, Brian.
Thanks for helping me out, I understand much better now
Old 11-08-2008, 09:58 PM   #5
Mcgyver
Liked 15 Times on 14 Posts
that's the way machinists do it, because its quick and accurate. skim any piece of steel to put a 60 degree cone on it and there's zero run out
Mcgyver is offline
Old 11-08-2008, 10:07 PM   #6
Mcgyver,
Makes a lot of sense, funny how you can't see the wood for the trees sometimes
Old 11-08-2008, 10:30 PM   #7
Mcgyver
on our little lathes it might not matter that much, but i can see why you'd want to avoid changing tool on a larger lathe......but I like to pretend I'm a machinist so that's how i do it
Mcgyver is offline
Old 11-08-2008, 10:38 PM   #8
John S
Because if you mount the centre in the headstock as is standard on some gap bed lathe you finish up with the saddle over the gap and unsupported.
Also you often have run out of bed length to get a bed stop on and still reach the end of the work.
Using a quickly trued up centre in the chuck will have the effect of moving the job down the bed a bit.
As others have mentioned it's also for the inherently idle
John Stevenson [ was JohnS the 3rd.]
Nottingham, England
John S is offline
Old 11-09-2008, 01:08 AM   #9
Thanks Guys, for all the good reasons for the 3 jaw chuck approach.
Filed away in my "I must remember that" box.
Old 11-09-2008, 11:58 AM   #10
Dhow Nunda wallah
Maryak, I've taken a similar approach myself.
Chuck up a bit of steel and put a point on it, then weld a "dog" on the end of the workpiece which will engage one of the chuck jaws. This allows you to turn all the way down the piece.
The dog is, of course cut/ground off after turning.
I may be a lazy bastard, but I'm good at it
Dhow Nunda wallah is offline
Right Facing and Turning, also Clockwise Turning? Antman Questions and Answers 6 08-28-2011 10:20 PM
Turning in the Mill doubletop Tools 12 01-08-2011 11:20 PM
Drilling centres in long bar without a fixed steady. Gauge3 Tips and Tricks 5 10-07-2010 12:54 AM
How to measure hole when boring between centres? SignalFailure Questions and Answers 26 12-15-2009 08:39 PM
Live centres SignalFailure Questions and Answers 11 05-15-2008 10:01 PM
