Home Model Engine Machinist > Building Them > Questions and Answers > lubricant for machining aluminum
Old 07-23-2008, 11:21 PM   #1
farmerbill13
Default lubricant for machining aluminum
I've used kerosene and wd-40 in the past,just wondering if there was anything cheaper that worked just as good?I'm machining cooling fins on a cylinder for a hot air engine.Thanks,Bill
farmerbill13 is offline
Old 07-23-2008, 11:45 PM   #2
Default Re: lubricant for machining aluminum
Welcome to HMEM Bill!
You'll never find a better cutting fluid for aluminium than straight kerosene.
It may not be the safest thing. I've had more than one little yellow flame
flair up in front of me.
There are some commercial products available such as Tap Magic Aluminium
Now THAT is the TOP of aluminium cutting fluids.
For the cost of 16 ounces of that you can buy a gallon of kerosene that is almost as good.
Old 07-24-2008, 12:05 AM   #3
farmerbill13
Thanks Rick,tap magic is good stuff,I have used it on deep hole tapping and reaming and your right about the price.
Old 07-24-2008, 12:10 PM   #4
LCT
WD-40 is my choice. I have heard some people get good results from automatic transmission fluid too.
Old 07-24-2008, 12:59 PM   #5
Florian
Liked 24 Times on 24 Posts
Hi Bill
I usually use denaturated alcohol. You will have to open the windows but it works quite well and the surfaces look nice.
Florian
Florian is offline
Old 07-24-2008, 05:37 PM   #6
JaguarB
Liked 6 Times on 3 Posts
I have been using Barbecue lighting fluid with good results
Paul
JaguarB is offline
Old 07-24-2008, 08:38 PM   #7
Metal Mickey
Liked 18 Times on 17 Posts
Does anyone know where you can buy clear cutting oil?
Have a look at my website ....... http://www.mikes-models.com
I use my lathe to turn 'a' round........then I go back....
Metal Mickey is offline
Old 07-24-2008, 10:28 PM   #8
Liked 627 Times on 506 Posts
There was some discussion on this on another thread. A-9 appears to be mineral oil with some additives. Perfume dye and a couple "secret" ingredients. So mineral oil from the drug store or big box store should work fine.Mineral oil is clear
Tin Falcon is online now
Old 07-25-2008, 12:41 AM   #9
I have a very OLD Machinery's Handbook here.
It is a 1st Editon printed in 1914.
(No it is NOT for sale!)
Aluminium was a precious metal then.
The book recommends "Rendered Beef Tallow" as a cutting fluid
for aluminium.
Cut a chunk of fat off a cow, boil it into an oil and your all set!
Well... It worked in 1914!
Old 07-25-2008, 12:53 AM   #10
Stan
Liked 29 Times on 29 Posts
Metal Mickey: Are you looking for a high sulphur cutting oil or a cutting fluid for some particular metal?
Tim: Those 'additives and secret ingredients' make a big difference in the mineral oil for cutting aluminum. Like the additives and secret ingredients your wife puts in the flour when she makes a chocolate cake.
Stan is offline
Effect Of machining speed on surface roughness in cutting 6061 aluminum Sshire Metals 4 08-03-2012 08:45 AM
Nanolube Lubricant Philjoe5 Special Materials 21 02-18-2011 01:11 AM
Why--What is going on with this Aluminum? Diy89 Questions and Answers 9 01-20-2010 05:00 PM
Lubricant tmuir Questions and Answers 7 04-30-2008 04:53 PM
aluminum Mike of the North Buy / Sell / Trade / eBay 1 04-14-2008 03:00 PM
