Home Model Engine Machinist > Building Them > Questions and Answers > Loctite, which one?
Old 01-30-2011, 06:06 PM   #1
DaveRC
Default Loctite, which one?
Loctite, which one just can't work out what I need
I need to loctite in some valve guides, bronze into aluminium.
I see people on here use Loctite for all sorts, I have never used it before, what do I get and how do you use it?
DaveRC is offline
Old 01-30-2011, 06:18 PM   #2
Metal Butcher
Liked 66 Times on 66 Posts
Default Re: Loctite, which one?
Dave, their are quite a few Loctite numbers that could work. But, If your parts span between a press fit and up to .005" gap, then I recommend #609. It has the correct viscosity to coat the surfaces properly. And its makes for a very strong joint. Its the one I use on all my work.
To use Loctite its important to degrease both parts with lacquer thinner (or equivalent) , coat both parts on their mating surfaces and install a with a one direction twist, or press them together quickly in one motion if the gap is a press fit. The closer the gap, the quicker it sets up. In the case of a press fit their will be no time to make any adjustments. You got to get it right on the first try.
-MB
In Constant Pursuit Of Perfection
Metal Butcher is offline
Old 01-30-2011, 06:28 PM   #3
dieselpilot
Liked 79 Times on 72 Posts
609 will probably be fine in a model engine, but if you expect the head to get hot you should consider the high temperature retaining compound, #620.
dieselpilot is offline
Old 01-30-2011, 08:39 PM   #4
Deanofid
Liked 150 Times on 147 Posts
Sleeve retainer. Both Loctite and Permatex make a version. They are specifically made for things like bonding piston sleeves and valve guides.
The Loctite number is 620 Retaining Compound.
The Permatex kind is just called High Temperature Sleeve Retainer.
Deanofid is offline
Old 01-30-2011, 09:19 PM   #5
Metal Butcher
I withdraw my suggestion of using Loctite # 609 to secure valve guides on an I.C. engine.
Deanofid and dieselpilot are correct with their recommendation.
I checked on the temperature ratings and Loctite #609 is rated at only 300 degrees Fahrenheit.
And the #620 is rated at 450-F.
-MB
Old 01-31-2011, 08:26 AM   #6
DaveRC
Thanks guys, good information as usual, now hunting for 620, any clues where to get this stuff. Have had a hunt on the net and it only seems to be in 250ml bottles (at over £100 ) can't seem to fin small bottles of the stuff...
DaveRC is offline
Old 01-31-2011, 02:57 PM   #7
DaveRC
Hi,
Just can't find the Loctite 620 at any reasonable price, can find Loctite 648, which seems to have very similar properties, only major difference I can see is the temperature range, max temp on the 648 is 175C or 347F, is this high enough for valve guides on an air cooled 4 stroke...?
DaveRC is offline
Old 01-31-2011, 03:39 PM   #8
QSPSB
Here are a few links that may help you... I would purchase a decent size bottle of this stuff... I'm sure you will need more in the future...
http://cgi.ebay.com/LOCTITE-Retaining-Compound-Type-Size-Strength-Green-ALL-/360332890026?pt=LH_DefaultDomain_0&var=&hash=item9 2af7985f4
http://www.midwayusa.com/viewproduct/?productnumber=171860&cm_mmc=Froogle-_-Gunsmithing%20-%20Tools%2C%20Jigs%20%26%20Fixtures-_-PriceCompListing-_-171860
http://www.strobelssupply.com/Loctite?product_id=200623
http://www.strobelssupply.com/Loctite?product_id=200622
http://www.strobelssupply.com/Loctite?page=7
Stoney
http://www.youtube.com/user/QSPSB
QSPSB is offline
Old 01-31-2011, 03:59 PM   #9
Metal Butcher
Hi,
Its very pricey stuff that #620. You cold use the Permatex equivalent called 'Sleeve retainer'.
Here's another option if you would like to buy a smaller lower cost amount. You could get on the phone to check price and availability at your nearest auto parts stores that stock Permatex products.
http://www.google.com/products/catalog?hl=en&client=firefox-a&hs=b7c&rls=org.mozilla:en-USfficial&channel=s&biw=1675&bih=849&q=permatex+ high+temperature+sleeve+retainer&um=1&ie=UTF-8&cid=12944109630016817937&ei=CelGTbqDOcT48Abw7NDc AQ&sa=X&oi=product_catalog_result&ct=result&resnum =5&ved=0CDYQ8wIwBA#
-MB
Old 01-31-2011, 04:42 PM   #10
milotrain
Liked 11 Times on 11 Posts
I would highly recommend getting Carroll Smith's book "Nuts, Bolts, Fasteners and Plumbing" as it's an interesting read about all fasteners but specifically he talks about a few of the Loctite verities and when/where to use them.
This is the google book result for the section on Loctite:
http://books.google.com/books?id=A81HmmRCN7YC&pg=PA129&lpg=PA129&dq=carrol l+smith+loctite&source=bl&ots=ZvrJAICFQz&sig=1MssJ Z4y3M5qAZNNVWwTD5RF45M&hl=en&ei=6fRGTe_NBo6ksQOHt5 WOCg&sa=X&oi=book_result&ct=result&resnum=1&ved=0C BsQ6AEwAA#v=onepage&q&f=false
milotrain is offline
loctite speedyb The Break Room 9 01-30-2013 04:06 PM
Loctite or solder? Sshire Questions and Answers 3 12-16-2011 04:09 PM
Help with Loctite 640 ozzie46 Questions and Answers 15 03-19-2011 11:55 PM
Loctite 1hand Questions and Answers 13 01-27-2011 02:20 AM
What kind of Loctite to use? dicej32 Questions and Answers 1 03-13-2008 04:59 AM
