Home Model Engine Machinist > Building Them > Questions and Answers > Lathe Tool Nose Radius?
Old 01-26-2012, 10:57 PM   #1
PerryRT
Default Lathe Tool Nose Radius?
So I've been fiddling around with grinding my own HSS lathe bits lately mostly using the old South Bend pamphlet that I got here:
http://dale.chatham.org/Interests/MetalWorking/HowToGrindLatheTools.pdf
It's been something that's been on my "list" for years - inserts are great, but I like to know about lo-tech methods too... and I suspect that the price of inserts won't be dropping any time soon. I've intentionally been making some "bad" ones so I can tell the difference between bad and good cuts in different metals.
Actually, I'm finding the "bad" ones easier to make, at the moment!
One thing's got me stumped, though. Nose radius. For the life of me, I can't seem to get a uniform nose radius on my tools - they generally come out... well..... lumpy. Non uniform. And certainly not to any specific radius known to man.
Barring some sort of jig, is this just one of those "experience things" I'll get better at? Or is there a trick to it?
Also, is it better to grind the nose radius parallel to the angle of the front clearance (i.e. after the front clearance, so that the nose radius can be seen down the relieved front edge of the bit?) Or before the front clearance so that the nose radius is only at the very top edge and fades as you move down the bit?
Regards -
Todd Perry
PerryRT is offline
Old 01-26-2012, 11:24 PM   #2
Liked 625 Times on 504 Posts
Default Re: Lathe Tool Nose Radius?
I grind all flats then hone all flats on an oil stone. then hone the radius on the same oil stone .
this thread explains and shows with pictures how I hone radii
http://www.homemodelenginemachinist.com/index.php?topic=15493.0
Old 01-26-2012, 11:41 PM   #3
PerryRT
Interesting! (Great pictures, btw) So you don't even radius on the grinder at all!
I have a set of Arkansas stones, but wasn't too worried about using them yet until I could get a feel for the angles and basics.... I'll try that!
Thanks!
Regards -
Todd Perry
PerryRT is offline
Old 01-26-2012, 11:58 PM   #4
If i am doing a small radius for regular turning I just stone by hand .
A bigger radius grind your flats then turn the grinder off and do two or three quick passes on the turning wheel to rough out the radius. then hone as mentioned before.
For a forming tool say a 1/16 inch radius on an 1/8 tool bit or larger then rough in on the grinder or belt sander then finish on a hone.
Also keep in mind the better grades of tool steel will last a lot longer in use but also take a bit more work to grind.
more info on HSS steel here
http://www.arwarnerco.com/warner_materials.html
Good people to deal with they support the hobby and quality is top notch made in USA Latrobe PA do not expect enco import prices but a good value I am a satisfied customer have never been disappointed in any of there products. I use there tools on a regular basis.
Old 01-27-2012, 05:47 AM   #5
Without a jig the "experience" or practice is the thing
I like to run mine all the way down the front edge so the is no chance of unwanted rubbing.
If you are right handed, the left hand holds the bit at the required angle to the wheel and the right hand rotates the tool using the thumb and forefinger of the left hand as the pivot point. (Well that's my way, developed unconsciously over the years, I only really thought about it when I tried to write it down )
On our size machines these radii are usually not much bigger than 1/16"
Hope this helps.
Old 01-27-2012, 07:12 AM   #6
tel
tel's Avatar
Liked 105 Times on 101 Posts
I do it the same way - and I'm left handed!
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 01-27-2012, 09:24 AM   #7
picclock
Liked 17 Times on 17 Posts
@ PerryRT
Read the South Bend tool grinding pdf and was quite surprised to find that it advocates having the tool height above centre (top of pamphlet page 6), by 5 degrees or 3/64 (1.2mm or about 0.5mm per cm) per inch of diameter when working with steel or cast iron.
I have never come across this before. Has anyone tried it and does it make a difference ?
picclock
From Ashtead, Surrey, United Kingdom
Dedicated to the art of efficiently transforming large useful pieces of metal into ever smaller pieces of scrap.
picclock is offline
Old 01-27-2012, 09:42 AM   #8
Omnimill
Liked 36 Times on 32 Posts
Likes Given: 33
I grind nearly all my tools on a belt sander and simply tip the table down a few degrees and grind the flats and radius at the same setting. The only tools that get honed are of the woodworking variety
Omnimill is offline
Old 01-29-2012, 04:28 PM   #9
Swede
Liked 27 Times on 27 Posts
The little diamond stones sold to sharpen knives - the solid ones, not the ones with holes in them - are perfect for putting a radius by hand on a HSS lathe bit.
I have always set the tool dead center for all operations, and it works fine. I cannot see that the recommendation you found would make much of a difference in a home shop. So much of that stuff, especially speed & feed recommendations, can be really baffling, but it's good to keep in mind that a lot of that data is created for a business machine shop where the absolute highest metal removal per unit time can be important for profitability.
Swede is offline
Old 01-29-2012, 11:41 PM   #10
PerryRT
You know, I read that and decided that perhaps that was advice for a rocker toolpost and didn't apply when using a QCTP....
I've always gone with square on the center line, and it seems to work OK both on my Sherline and my 9x30.
Thanks to everyone for the advice. I cut a new bit this afternoon and spent a couple of minutes rounding it by hand (as Tin Falcon) suggested.
Easy enough, and a lot more controllable than doing it on the grinder. I may try that again in the future, but this works for now.
Thanks!
Regards -
Todd Perry
PerryRT is offline
No Bull Nose Center rake60 Tips and Tricks 8 06-16-2012 12:54 PM
Radius grinding a lathe tool gld Tips and Tricks 12 12-29-2011 02:38 PM
Radius turning tool vid kustomkb Links 5 03-04-2011 03:25 AM
Radius, Bead Tool MachineTom Tools 4 01-16-2011 04:36 PM
Single size radius groving tool deere_x475guy Tools 13 01-05-2008 10:34 PM
