Home Model Engine Machinist > Building Them > Questions and Answers > Increase in Compression
Old 10-01-2012, 11:58 AM   #1
Liked 2273 Times on 2034 Posts
Default Increase in Compression
All 3 of the i.c. engines I have built have undergone a remarkable increase in compression after being ran for about 2 to 3 hours. I realize that this is a result of the internal components "wearing in". They all have Viton o-rings instead of cast iron rings, and they all have 01 steel valves with brass valve cages. I don't know how much a Viton o-ring has to "wear in" but there must be some factor involved. I think that what happens with the valves is that the steel valves, being a lot "harder" than the brass seats, must actually "pound" their individual profile into the brass seats until they are a perfect match at the microscopic level.---this as a result of heat and the pressure of the valve spring seating the valves after each firing stroke, and the pressure on the valves created by the combustion itself. I know the engines rotate more freely as a result of the camshaft and crankshaft bushings wearing in, but this is a totally different issue than the increase in compression. Each of my 3 engines have different material in the cylinder. The Webster is mild steel, with aluminum piston, the Kerzel has a 316 stainless cylinder barrel with an aluminum piston, and the Atkinson has a grey cast iron cylinder and piston. Lets hear opinions on this phenomenon of increasing compression after engines have ran for a few hours!!!---
Old 10-04-2012, 01:23 AM   #2
lee9966
Liked 11 Times on 11 Posts
I have seen the same on my few engines. I came to the same conclusion as you, the valves must be sealing better. Perhaps carbon buildup helps?
Lee
lee9966 is offline
Old 10-04-2012, 02:09 AM   #3
gbritnell
gbritnell's Avatar
Liked 265 Times on 365 Posts
The only thing it can be is the valves. I would think that with the flexibility of the 'O' ring that it would seal any mismatch right from the get-go. Usually an engine's compression increases as the rings seat in because being made from metal they wear to match any minute irregularity in the cylinder wall.
When you say "remarkable" what exactly does that mean? The engine would need adequate compression to even begin to run so how much more has it gained with running?
gbritnell
Talent unshared is talent wasted.
gbritnell is offline
Old 10-04-2012, 04:11 AM   #4
Entropy455
Liked 47 Times on 36 Posts
I don’t have much experience with small engine valves. I can say however that larger engine valves (i.e. automotive gasoline and diesel engines) will properly seal from the moment they’re installed - provided the valve guides are perpendicular with the seats, and that the valve & seats are properly ground and lapped in. Normally compression issues during the break-in period are a result of ring seating.
One thing is for sure – the air is blowing by somewhere prior to break-in, and is doing so less afterwards.
Mathematically, a perfectly round O-ring will have an undefined surface area against the cylinder wall (a pure tangential line of action). Pressure is equal to force per unit area – thus if the O-ring is round, it will have no defined area against the cylinder wall, and be incapable of holding back any pressure. Obviously there is a slight interference fit, which causes the O-ring to deflect into the cylinder wall creating a real sealing surface. Nonetheless, perhaps the O-ring even better conforms to the cylinder wall after a break-in period? Either by stress-relieving and conforming from the heat cycle(s), or maybe the O-ring develops a small flat-spot against the cylinder from friction?
How smooth is the bore? I.E. maybe the O-ring is somehow polishing the cylinder?
I’ll be following this post with interest!
Entropy455 is offline
Old 10-04-2012, 11:52 AM   #5
Henry
Henry's Avatar
Liked 4 Times on 5 Posts
Likes Given: 264
I think that there is also a microscopic (sometimes a lot )amount of residues from the combustion in the engine surfaces that help to do a closest fit.
Henry is offline
Compression ratio??? HYTECH Questions and Answers 6 03-20-2012 02:11 AM
pipe diameter increase willisZ Questions and Answers 16 01-01-2012 04:19 PM
compression ratio's jct842 Questions and Answers 6 05-18-2011 12:48 AM
Alibre Price increase Tin Falcon Software and Programming 1 04-30-2011 09:02 AM
None Compression Engine lathe nut Photos and Videos 3 12-20-2009 03:11 AM
