Home Model Engine Machinist > Building Them > Questions and Answers > Gluing Delrin
Old 10-27-2010, 12:08 AM   #1
kcmillin
Liked 70 Times on 67 Posts
Default Gluing Delrin
What, if any, type of glue can I use to join two pieces of delrin (acetal)?
Will a press fit hold nicely?
I am trying to come up with a design for a distributer cap.
Kel
Machinists do it with precision.
www.burleighmachine.com
kcmillin is offline
Old 10-27-2010, 12:52 AM   #2
Liked 2273 Times on 2034 Posts
Default Re: Gluing Delrin
I don't think you can glue Delrin.
Old 10-27-2010, 01:25 AM   #3
Metal Butcher
Liked 66 Times on 66 Posts
Kel
Hi Kel, you could try some Bondit b45th. I think McMaster Carr might carry it.
http://www.reltekllc.com/bondit-b45th.html
Don't know what all of this below means, but it was fun reading.
http://en.wikipedia.org/wiki/Acetal
-MB
In Constant Pursuit Of Perfection
Metal Butcher is offline
Old 10-27-2010, 01:44 AM   #4
Metal Butcher
Here is something that may work. Etching the surface's seems to be a necessity.
http://www.loctiteproducts.com/products/detail.asp?catid=17&subid=40&plid=661
-MB
larry1 Likes This
Old 10-30-2010, 06:56 PM   #5
Peter.
I followed Evan Williams' guide to making leadscrew nuts from Acetal by heating the leadscrew with a heat gun and it welded the two halves of the nut together very well. Might be possible to do a variation of this?
Peter. is offline
Old 10-30-2010, 08:21 PM   #6
Delrin is usually welded.
When I was in work. we used to have cleaning tanks welded up out of delrin sheet.
Bogs
Old 11-17-2010, 11:12 PM   #7
Ed T
Nothing to add on the glueing question, but you might want to check into the moisture absorbtion of DELRIN. Might make it a poor choice for a distributor cap.
Ed T is offline
Old 11-17-2010, 11:56 PM   #8
Lamachina58
I've done a bit of prototype work and a lot if injection molding of Acetal (Delrin is tm). I never have bonded parts but if I can explain this, have created a mechanical "lock" made of epoxy.
If you have a shaft in a bushing. Groove the i.d. of the bushing and at the same location, groove the shaft. Assemble with those grooves full of epoxy and at the right location. You essentially have a solid o-ring and neither part can move. I've done that with a lot of dis similar materials, no threading and it doesn't take much of a groove.
Delrin doesn't absorb much moisture but for heat resistance and electrical situations I have used Ultem. Very machinable, good temperature resistance, expensive but I use onlinmetals and they cut short pieces. Ten buck for a foot of 1" dia.
I am new to forums, can I mention a supplier??
Lamachina58 is offline
Old 11-18-2010, 01:47 AM   #9
jpeter
Liked 50 Times on 45 Posts
I've made distributor caps from Delrin. They work great. Don't work well wet though. Need to dry out after cleaning.
jpeter is offline
Old 04-09-2013, 01:55 PM   #10
jmassen418
Hi,
I just tried Plastic Weld from Plastruct. No good.
jmassen418 is offline
adhesive for Delrin (acetal) Marty Feldman Metals 3 12-04-2011 08:43 PM
Glue for Delrin..? DaveRC Questions and Answers 3 03-22-2011 12:55 PM
delrin on delrin any good or bad idea? jack404 Questions and Answers 17 11-08-2008 07:27 PM
