Home Model Engine Machinist > Building Them > Questions and Answers > Flat Belts and Model Engines?
Old 01-18-2013, 11:57 AM   #1
Generatorgus
Generatorgus's Avatar
Liked 175 Times on 111 Posts
Likes Given: 31
Default Flat Belts and Model Engines?
I can't seem to find anything. The wheels of progress are turning in my head. Crowned pulleys, flywheels, belts
GUS
Generatorgus is offline
gus Likes This
Old 01-18-2013, 12:33 PM   #2
Can you be more specific, what sort of scale, flat belts and the propper joining clips are available in certain scales.
Would also help to know where in the world you are rather than suggest suppliers thousands of miles away.
narrowgauger Likes This
Old 01-18-2013, 02:43 PM   #3
deverett
Liked 55 Times on 49 Posts
I've also often pondered this question. What do you use for flat belts about 1" wide?
From UK, I have tried green flat plastic belting as sold by one of the traction engine casting suppliers (LSM from memory), but it is too stiff and slips. Doesn't look very authentic, either. Now I'm thinking of making my own from thin leather. Cutting with a Stanley knife to width over the required length - say 6" between pulley centres, about 16" long - using a steel rule as a straight edge. The ends could then be scarfed and glued with Evostik or similar type latex glue and the joint stitched to prevent the ends peeling apart.
Any other suggestions?
The Emerald Isle
deverett is offline
Old 01-18-2013, 05:14 PM   #4
GailInNM
GailInNM's Avatar
Liked 189 Times on 159 Posts
Likes Given: 36
For flat belts up to about 3/8" (9mm) wide, a large number are available for electronic device service. Things like turntables, VCRs and similar devices.
The best USA source that I have used for these is:
http://www.mcmelectronics.com/browse/Belts/0000000162
They have flat, round and square belts and you can select what you want from the check box on the left side of the above link. The nice thing about MCM is they give the actual size and not just "this belt fits XYZ###" device.
Gail in NM
Gail in New Mexico, USA
I would like to be the kind of person my dog thinks I am.
GailInNM is offline
Old 01-20-2013, 10:18 AM   #5
Generatorgus
Likes Given: 31
Jason, good question, sometimes I feel like everyone should be on the same page I am, how untrue. You may notice that I have now released a clue to the location of my hideout.
I'm thinking in the 1/2" width range.
My first thoughts are, like Dave suggests, leather but I'm thinking that leather won't work as it would probably have too much stretch at that size range, unless you could possibly prestretch it.
Green is positively out of the question, it would destroy the look.
And, although I would rather any such belting would at least look "leatherish", I woudn't mind doing some experimentation, perhaps leather laminated on a more substantial substrate, but I think thickness would probably limit that. Or posibly faux leather?
Gail's link would be the easiest if the belting could be spliced to length, or the project be sized to existing belt sizes, but is subject to the "leather look" limitation, but better than green.
Still wondering if the crowned pullies or flywheels would function as in real life size machinery.
Oh yeah, I'm thinking about driving a generator, of course.
GUS
Old 01-20-2013, 11:18 AM   #6
trumpy81
Liked 37 Times on 26 Posts
Gus, you could use leather. Simply soak it in water for a day or so and then let it dry in the sun for about a week, that should take care of any stretching that might occur. You could then splice and glue together and use simple paper staples to represent the hinge and pins (forgot what it's actually called ... doh!).
Food for thought.
Andy M
Skype - live:ivatrumpy
trumpy81 is offline
Old 01-20-2013, 01:05 PM   #7
canadianhorsepower
Liked 150 Times on 120 Posts
Likes Given: 651
GUS
Hi try this supllier, I've been using it for over a decade building robots
and doesn't matter what I think.... they carry it
http://www.sdp-si.com/
canadianhorsepower is offline
Old 01-20-2013, 03:21 PM   #8
deverett
Originally Posted by trumpy81 View Post
Snip ... and use simple paper staples to represent the hinge and pins.
STAPLES. That's a darn good idea. Much easier than sewing!
The Emerald Isle
deverett is offline
Old 01-21-2013, 11:52 AM   #9
Generatorgus
Likes Given: 31
Guys, thanks for the replies and links. At least I have some options to ponder.
Trumpy, I think they're called laces. I have a full size belt lacer.
GUS
Old 01-22-2013, 10:07 AM   #10
trumpy81
GUS
Thanks Gus. I knew it was something simple but just couldn't prod the grey matter into giving it up ...
I'll try not to forget it next time
There's a couple of videos on YouTube about lacing, one is by Tubalcain (MrPete22) and the other by Keith Fenner. Both worth watching even if you're an old hand at it.
Andy M
trumpy81 is offline
V6 Model Engines... BlakeMcKee Questions and Answers 12 12-16-2010 11:14 PM
Model Airplane Engines. Metal Butcher Plans 3 12-26-2009 03:56 AM
Screws for model engines D.C.Clark Questions and Answers 14 08-23-2009 10:47 PM
Small Flat Belts Supplier [ UK ] Bluechip Links 0 01-03-2009 07:57 AM
Why build model engines? Tin Falcon Welcome 2 08-01-2007 01:27 AM
