Home Model Engine Machinist > Building Them > Questions and Answers > edge finder
Old 09-10-2010, 07:11 PM   #11
speedhound
Liked 1 Times on 1 Posts
Default Re: edge finder
Hi, i was orginally going to get a lazer one but i decided to cheep out and get a touch point one, probilly from chronos.
speedhound is offline
Old 09-10-2010, 11:22 PM   #12
Joachim Steinke
Joachim Steinke's Avatar
Liked 22 Times on 15 Posts
Hi folks
I know you are primarily discussing the aspects of touch point edge finders here, but I want to take the opportunity to show you another (definitely not new) approach to the theme “finding edges” on the milling machine.
I have, like many others of you, a variety of conventional mechanical edge finders in my shop for several years now
but since I made my own finders based on simple ball bearings the commercial ones are very seldom in use.
To make this type of edge finder you only need two things, a suitable ball bearing and a true running shaft. For the shafts I like to use ground dowel pins, they are straight enough for this job and have a precise diameter. Our German dowel pins with m6 fit have nearly no clearance to a ball bearing hole. So normally you get a slight press fit from only pushing them into the bearing and this will fix things strong enough. But needles to say you can use any sort of straight self turned shafts also and if you have problems with a precise press fit to the bearing a drop of Loctite might help a lot.
To me that sort of edge finders have several advantages:
They are cheap and easy to build, so you can make a whole assortment of that useful helpers for different shop tasks. Most of you will have all the needed components in your drawers anyway.
You can make several edge finders with different shaft diameters of your main collet sizes, so you don’t have to change collets so often when using a variety of tooling on the mill.
Ball bearing finders work proper in a wide range of spindle speed, you can use them up to 4000 rpm and even more without any problem. This can be very useful on machines without variable speed control, no more drive belt altering when changing to the edge finder while you are on “high speed” milling operations.
And the edge detection is really precise and easy to read, to my experience +/- 0.01mm (0.004in) ore even better is always reproducible.
To get an impression how it works you can have a look at this little video, the mill is running with 3000 rpm at this time:
http://pl-hi.de/JST/Ball-Bearing-Edge-Finder-01.mpg
And here is the scenario for another video using a dial indicator
to demonstrate the reproducibility when getting in contact with the surface of your work piece. The counter has a graduation of 0.01mm.
http://pl-hi.de/JST/Ball-Bearing-Edge-Finder-03.mpg
Good Night
Achim
Joachim Steinke is offline
Old 09-11-2010, 02:00 AM   #13
SAM in LA
Liked 34 Times on 34 Posts
Achim,
Very clever.
Thank you for sharing.
SAM
SAM in Lower Alabama, USA
SAM in LA is offline
Old 09-11-2010, 03:06 AM   #14
Lew Hartswick
Originally Posted by SAM in LA
Achim,
Very clever.
SAM
Yes too bad the links don't run.
...lew...
Lew Hartswick is offline
Old 09-11-2010, 03:19 AM   #15
cidrontmg
Liked 11 Times on 10 Posts
Likes Given: 22
Lew, I think it would be a good idea to d/load the video files to your machine first, and watch from there. That way, they work just fine. The first is 2.1 Mb, the second is 3.85 Mb, so with any decent broadband, it´s just an instant to d/load..
Olli
cidrontmg is offline
Old 09-11-2010, 04:41 AM   #16
Majorstrain
Liked 13 Times on 12 Posts
Very impressed Achim,
I'll have to make some of those.
Phil
Majorstrain is offline
Old 09-11-2010, 06:21 AM   #17
Peter.
I like those too - thanks for posting it up!
Lew, the links run fine for me using GOMplayer.
Peter. is offline
Old 09-11-2010, 09:01 AM   #18
Joachim Steinke
Good morning
Sorry if some of you have problems with my videos.
I have just uploaded them to you tube, here are the two links:
I hope this might help a bit.
Achim
Old 09-11-2010, 09:23 AM   #19
tel
tel's Avatar
Liked 105 Times on 101 Posts
The links work OK for me as well. Excellent idea - I'll be hunting through my bearing drawer first thing in the morning!
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 09-11-2010, 11:23 AM   #20
GailInNM
GailInNM's Avatar
Liked 191 Times on 161 Posts
Likes Given: 36
Thats a great idea, Achim.
Thanks.
I could not get the original video to open either but the Utube video works fine.
Gail in NM
Gail in New Mexico, USA
I would like to be the kind of person my dog thinks I am.
GailInNM is offline
Edge Finder Heads Up Ken I Tips and Tricks 28 08-24-2012 12:13 AM
How to use a Conical Edge Finder vascon2196 Questions and Answers 6 04-25-2012 12:57 AM
Micro edge finder Swede Photos and Videos 5 11-23-2011 03:26 PM
Edge Finder Operation metaldestroyer Tools 9 01-28-2011 03:57 PM
Laser edge finder don-tucker Questions and Answers 21 12-03-2010 01:51 PM
