Home Model Engine Machinist > Building Them > Questions and Answers > Drill size for M5 tapping?
Old 07-12-2010, 07:12 AM   #1
student123
Default Drill size for M5 tapping?
I need to drill & thread into macine grade ali for a M5 bolt
web search says use 4.2mm hole. My drill bits run 4mm then 4.5mm
cant see a straightforward imperial equivalent to 4.2mm.
better to go with the 4 or the 4.5mm bit to drill the hole?
Mike
student123 is offline
Old 07-12-2010, 07:29 AM   #2
JimM
Default Re: Drill size for M5 tapping?
I normally use a 4.5mm and haven't had any problems to date - in fact I think 4.5mm is the size you would use for a fine pitch M5
HTH
JimM is offline
Old 07-12-2010, 07:44 AM   #3
tel
tel's Avatar
Liked 105 Times on 101 Posts
You will get away with a 4.5mm for M5, but you really should get the proper 4.2mm. In fact, the best investment any workshop that deals with metric threads can make is a set of 1 - 5.9 x 0.1 steps drills.
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 07-12-2010, 08:23 AM   #4
bob ward
Liked 18 Times on 18 Posts
You're not making parts for the Hadron Collider so a 4.5mm drill will work as has been said.
Personally I would procure a 4.2mm drill bit, seeing as you are in the UK you shouldn't have any trouble finding one.
bob ward is offline
Old 07-12-2010, 08:41 AM   #5
Liked 627 Times on 506 Posts
print a copy of this
http://littlemachineshop.com/Reference/TapDrillSizes.pdf
Old 07-12-2010, 10:40 AM   #6
Bluechip
Mike
Mike
This is a source in UK, I've found them to be very good value for the price. You can just get the individual sizes for tapping small Metric. Although it would be better to get a set as Tel says. You will find some materials tap better with a tenth or so larger than the nominal size.
http://www.axminster.co.uk/axminster-packs-of-5-ground-hss-drill-bits-prod20559/
Dave BC
Bluechip is offline
Old 07-12-2010, 11:29 AM   #7
Ned Ludd
Hi Mike,
The Imperial equivalent to 4.2mm is a number 19 drill. Personally I would use a 4.3 or number 18 (80% thread engagement), but anything up to 4.5mm(60%) will do, depending on material and application.
If you aim for 75-80% engagement, especially on small size threads you will break fewer taps, not that anybody on this site is clumsy enough to break any of course.
Ned
Ned Ludd is offline
Old 07-12-2010, 04:06 PM   #8
Lew_Merrick_PE
Hi Mike,
If you go to http://www.scribd.com/Lew%20Merrick, you will find a document Pilot Hole Considerations that gives the equations for calculating different fits of pilot (tap drill) holes and their impact on the strength of the joint. The "standard" tap drill is supposed to create a 75% of full-thread engagement threaded hole. This is a convention based on providing maximum tap life in most instances along with generally acceptable axial load carrying capacity in the joint. If an actual 75% of full thread engagement is used, then the joint is 90% as strong as a 100% full thread engagement joint.
The standard M5 thread is more formally defined as M5 X 0.8mm pitch thread. A ø4.5 mm pilot hole in this instance would create a 48% of full thread engagement joint. This would be joint that is 53% as strong as a 100% full thread engagement joint in axial loading. That would be the best you could get from the joint as other factors (quality of the tap, quality of the tapping set-up, etc.) would degrade the value from there.
Yes, 90+% of the time using an oversized (by the chart) tap drill will work just fine. The problem is that a real answer requires an understanding of the application and loading of the joint. The thing working in your favor is that most designs use screw/bolt sizes significantly greater than actually required. A typical 1100 MPa yield strength M5 screw will not yield until 13.8 kN of force is applied to it. Designers often use "eyeball sizing" rather than looking at the actual loads. This leads to conditions of (1) using a much larger thread than necessary; or (2) failing the thread (usually when the screw or bolt goes into bending mode).
Old 07-12-2010, 05:01 PM   #9
11/64ths would be a reasonable fractional size to use if you don't have letter/number drills.
Jason
Old 07-12-2010, 05:32 PM   #10
arnoldb
arnoldb's Avatar
Liked 91 Times on 176 Posts
Mike, you've been given a lot of good advise.
As a side note, I also use metric most of the time. I learned early on that the places where I can buy taps also sells the correct tap drills, and I make it a point to buy the correctly sized tap drill (or a couple for <4mm taps) when I buy the taps. I then store the taps and their drills together, separate from my "normal" drill bits. This saves a lot of frustration when it comes to tapping.
As another aside, this works well for drills for reamers as well; for my reamers up to 8mm, I buy high quality drills that are 0.1mm undersize, and test them to drill to size (not over size), and then keep them with the reamers. Above 8mm, I use drills 0.2mm under size e.g. a 9.8mm drill for the 10mm reamer. This also saves a lot of frustration later on.
Regards, Arnold
"Necessity, who is the mother of invention" - Plato
arnoldb is offline
Tapping size hole for 1 1/8 whitworth firebird Questions and Answers 16 10-23-2011 08:44 PM
Tapping drill rod/silversteel... is it just a PITA? TroyO Questions and Answers 5 02-07-2011 03:39 PM
Tapping drill size firebird Questions and Answers 7 03-25-2009 10:26 PM
Simple Question Re: Tapping Drill size CrewCab Tips and Tricks 11 08-04-2008 04:51 AM
drill size vs reamer size joe d Questions and Answers 9 04-08-2008 06:10 AM
