Home Model Engine Machinist > Building Them > Questions and Answers > drafting symbols - what does this mean?
Old 05-30-2009, 02:18 AM   #1
zeeprogrammer
Liked 170 Times on 170 Posts
Default drafting symbols - what does this mean?
I'm looking at a drawing - at a symbol I've never seen before.
I was top of class in drafting - but that was 40 years ago. (That's right - pre-cad). And...I've only started machining a few months ago...so my knowledge is both old and limited. Okay, I'll say it, near non-existent. (Now show me a schematic and I'll say...yep...that's what it is...a schematic.)
In any case...
The symbol looks like a large check mark (or V with one leg shorter than the other) with a number inside. One shows 32 and another 64. The part I'm looking at is the crankshaft for a launch engine. (Basically a rod with a disk on one end.) The symbol with the 32 is on the rod while the 64 is on the disk. What do they mean? I'm thinking tolerance but it don't make sense to me.
While I'm here... the diameter of the rod (shaft) is called out as:
.2183 DIA REF. - SLIT FIT
.0005 CLEARANCE WITH DET.
#3.00.040-01 & 3.00.020-01
I'm thinking 'SLIT FIT' should be 'SLIP FIT'?
I get the .2183 (and good luck getting .---3).
And sorry to keep demonstrating my ignorance (maybe I shouldn't have had the wine...but it's Friday night)...I'm now confused about 'REF'. Help. (And don't just tell me 'reference'....and at least one of you won't be able to help themselves. )
0.0003 hahahahahahaha...that's rich...hahahahahaha...like I can do that...hahahaha
I'm happy if there's metal left when I'm done.
Thanks.
No. No machining tonight. Long week. Wine was more medicinal than anything else. (Sure. Sure.)
To work. To work.
zeeprogrammer is offline
Old 05-30-2009, 02:45 AM   #2
te_gui
Default Re: drafting symbols - what does this mean?
That specifies the desired surface finish in micro inches. That symbol was probably there 40 years ago, but may have slipped away. They make gages that give an example of the various finishes called comparators, basically you drag your fingernail across the standard, then your part and compare them. Kinda like "scratch and sniff" which is another name for the gages. I like to think of a 125 finish as kind of your average milled finish, a 250 is a saw cut and a 16 probably has to be ground to achieve although you can come pretty close with the right combination of insert and hard material. They also make profilometers that drag a stylus across a part and measure all the little peaks and valleys and come up with a number, but doubt you will find too many of them in a hobby shop. I'm sure if you google surface finish, you will find more then you ever wanted to know.
Brian
te_gui is offline
Old 05-30-2009, 02:47 AM   #3
Those are Surface Finish marks.
A 32 RMS finish is very smooth.
A 64 RMS finish is even smoother, like glass...
At work we use an electronic profilometer to measure surface finishes.
One night a few of the young guys decided they should try it on my
bald head to see just how smooth it was. I did sit still for that and
found out that the top of my head was a 30 RMS Surface Finish.
Then one of them suggested polishing it up with some Scotch Brite
to see if they could improve the reading.
I RAN!
Old 05-30-2009, 03:09 AM   #4
zeeprogrammer
Thanks Brian and Rick.
What does one do to achieve the specified surface finish? Get one of them profilometers or grow my nails out and test and polish? Do hobbyists typically try to achieve that? Or would the hobbyist say 'hm...looks like it needs to be pretty smooth'?
Rick...for the pate you need a very very soft and fine cloth...then find a professional shoe shiner. They'll fix you up and it'll feel great. A little music and you got entertainment. Slappity slap slap. Go for it. Friends will appreciate it. Saves them from hunting up a mirror. Just don't let them breath on it and try to rub the smudges off.
To work. To work.
Old 05-30-2009, 03:15 AM   #5
te_gui
Hey Rick,
You might wanna check your figures, typically smaller numbers mean smoother.
Brian
te_gui is offline
Old 05-30-2009, 03:19 AM   #6
An electronic profilometer runs about $1500.00
OR, you can buy an old school finger nail scratch gauge for
about $9.00 This is a photo of mine.
It can be found here:
http://store.flexbar.com/merchant2/merchant.mvc?Screen=PROD_IM&Store_Code=FLX&Product _Code=16007&Category_Code=Surf-Rough-Comp
You are correct Brian.
Smaller numbers are finer finishes.
Old 05-30-2009, 03:24 AM   #7
Marinesteam
Rake60
You may want to check your post... The smaller the number the smoother the surface. Did you succeed in improving the finish?
As far as what a hobbyist can do...
There is a chart in Machinist Handbook called "Surface roughness produced by common production methods" on page 708 of the 25th edition big book. 64-32 Ra is in the range of Turning - Boring though on the smoother end of the range. A good turned surface finish should be within the range of most machinists capabilities.
If you want to be more sure. Most tool suppliers offer a surface finish plaque standard for machining operations (they are made for injection molded finishes as well). A rub with a finger nail on the plaque and across the machined surface will tell you if you're in the ballpark. That and a look with an eye loupe will get you pretty close.
Marinesteam
Marinesteam is offline
Old 05-30-2009, 03:28 AM   #8
te_gui
Yup, theres the "scratch and sniff" gage. To answer the question about achieving the finish in the hobby shop, thats where emery cloth comes in. In the manufacturing world, you never wanted to call out a smoother finish then needed since it generally gets more expensive to create it. In the model world where "bling is king" the rules are different. I have had hydraulic cylinder rods that were too smooth and wouldnt hold an oil film, causing excessive seal wear as well as "stick slip" while moving, so you can over do it.
Brian
te_gui is offline
Old 05-30-2009, 03:33 AM   #9
Don't underestimate the "scratch and sniff" gauge.
An average piece of paper is .0023" thick.
Hold it flat on a table, close your eyes and run your finger over the
edge of it. It feels a whole lot thicker than 0023"...
Old 05-30-2009, 10:22 AM   #10
scoop
We used "Rubert blocks" for years until hand held surtronic machines were available.There must be thousands of sets of these kicking about in old workshops.They still have a website at... www.Rubert.co.uk
Different sets for different machining operations,although I seldom see any indication of required surface finish on model engineering drawings.
best regards Steve C.
non plaudite-modo pecuniam jacite.
scoop is offline
drawing symbols kwoodhands Questions and Answers 5 05-09-2012 09:22 PM
Get Your Free Drafting Software Here kcmillin The Break Room 4 04-18-2010 10:42 PM
Mechanical Drafting questionssssss. hobby Questions and Answers 30 01-29-2010 11:25 PM
Plans & Designs - Symbols? JimM Questions and Answers 2 06-26-2009 05:57 AM
Need Info on Part Drawing Symbols and their Meaning wheelterrapin Questions and Answers 3 12-17-2007 12:40 AM
