Home Model Engine Machinist > Building Them > Questions and Answers > Clarke CMD300 Mini Mill replacement circuit board
Old 10-02-2010, 04:40 PM   #1
colin104
Default Clarke CMD300 Mini Mill replacement circuit board
Owned my Clarke CDM300 mini mill for three years,great little machine (now).Arrived in crate complete with ample amounts of swarf and paint chips,completely stripped down cleaned and rebuilt.Machine has worked well over the years,unfortunately the electrics died today.Unable to locate replacement board,new or exchange.I will be very grateful for any information.
Regards Colin
Added picture may help,one LED not alight
colin104 is offline
Old 10-02-2010, 05:11 PM   #2
Liked 625 Times on 504 Posts
Default Re: Clarke CMD300 Mini Mill replacement circuit board
Assuming the clark is a seig x-2 and the board looks like this
order one here
http://littlemachineshop.com/products/product_view.php?ProductID=1211&category=
or it can be repaired here
http://www.repaircontrol.com/
there is also info on troubleshooting and repair if you are good at electronics.
I had the boards on my mini mill and lathe go at the same time they were repaired with the help of a buddy at work for less than $10 in parts . just a couple of fried diodes. the diodes are usually the first to go then the MOSFETs .
Old 10-02-2010, 06:37 PM   #3
colin104
Thanks TIN
Had a look round the sites you suggested,cant find any that look like mine.
I have added a picture,if any body finds one please keep me in mind.
colin104 is offline
Old 10-02-2010, 08:12 PM   #4
John Rudd
Colin,
I've sent you a (pm) private message re your circuit board...
eccentric millionaire sponsored by 'er indoors
John Rudd is offline
Old 10-02-2010, 08:22 PM   #5
max corrigan
Send a message via AIM to max corrigan Send a message via MSN to max corrigan Send a message via Yahoo to max corrigan
Originally Posted by colin104
Regards Colin
Colin try Arc Euro i had to buy a Speed control board for X1 mill last February they have a good site with pictures numbers etc. not cheap though £70 post free, for the board very easy to fit though worth a try they are good people to deal with
Regards Max............
max corrigan is offline
Old 10-02-2010, 10:19 PM   #6
John S
There should be a part number on the board XMT2325 or XMT 2335
The 2325 fits the C2 lathe, Arc has these at £60, in stock
http://www.arceurotrade.co.uk/Catalogue/Machine-Spares/C2-Mini-Lathe-Spares
The 2335 fits the C3 lathe, Arc has these at £80, in stock.
http://www.arceurotrade.co.uk/Catalogue/Machine-Spares/C3-Mini-Lathe-Spares
The boards look identical, only the numbers differ.
John S.
John Stevenson [ was JohnS the 3rd.]
Nottingham, England
John S is offline
Old 10-03-2010, 12:19 AM   #7
kf2qd
kf2qd's Avatar
Liked 25 Times on 30 Posts
YOu might also look into standard comercial DC motor drives from manufacturers like Minarik and others. You will get cleaner motion, more torque and the motor will be happier. Won't cost much more, but will work a lot better.
I replaced mine 4 years ago and have not missed the original board. More torque and less heating.
KF2QD, South Texas
HF MiniMill
HF 7x10
Hardinge UM
kf2qd is offline
Old 10-12-2010, 04:46 AM   #8
colin104
Originally Posted by John Rudd
Colin,
Sorry for delay in replying,broadband down for one week.Thanks for your kind offer to look at the board,please read below board may be O/K.Tried Arc Euro Trade as advised by John Stevenson many thanks ,gave them my board number Xmt 2335 two in stock.Told by Arc Euro not for your mill?.Managed to contact clarke spare parts,gave the number on my board.Salesman stated he had no idea of the board numbers,his computer said boards in stock would fit my mini mill.Disparate by know i ordered one £84.89,when delivered board number xmt 2325 sods law still working.Decision time return or fit,i chose the later.Fitting board not a problem (cable id sleeves are loose secure them or as i did change one cable at a time)all connections on both boards identical.Time to switch on it worked,
completed job in hand then mill refused to start.Switching on and off two or three time started mill,witch now points to intermittent problems with switch or potentiometer.Will keep you posted.
colin104 is offline
Old 10-12-2010, 08:44 AM   #9
John Rudd
The pot on these is notorious for causing various symptoms....
The pot on my Chester mini mill gave up fairly early in life....Its a special so cant be repalced by any of the offerings from the likes of Maplins....
I changed mine but modded the circuitry by adding a switch that requires pressing before the mill will run.......
Old 11-14-2010, 06:16 AM   #10
colin104
The pot on my Chester mini mill gave up fairly early in life....Its a special so cant be replaced by any of the offerings from the likes of Maplins....
I had the same problem locating and identifying part number for replacement unit.The manual supplied with the mill gives 134 as speed control knob,clarke spares unable to tell me if switch is attached.Clarke sent as replacement a 4.9k potentiometer without switch.After three weeks of emails and phone calls,thy sent me a unit removed from a new machine.Mill know running
perfectly.Old switch tested with meter no defect found for twenty cycles then failed,then returned to normal operation?.
Please take care when faced with above problems,costs less to replace switch than circuit board.Cost to date just over £90
but at least I have spare circuit board.
colin104 is offline
Printed circuit board, pcb, milling ttrikalin The Break Room 37 07-02-2013 05:50 PM
FS mini mill Steelburner Buy / Sell / Trade / eBay 6 08-14-2011 12:28 AM
mini mill ? sourdoughsmitty Tools 7 01-12-2010 03:00 PM
Poor Mans DRO going on a Clarke CLM500 PhiberOptix Machine Modifications 4 08-19-2009 06:19 PM
Clarke Power Products (Clarke welders) is in Chapter 11 USA PTsideshow The Break Room 0 07-06-2009 01:45 PM
