Home Model Engine Machinist > The Tools and Tips > Tips and Tricks > Miniature Cotter Pins
Old 05-03-2008, 06:08 PM   #1
Oldmechthings
Liked 27 Times on 21 Posts
Default Miniature Cotter Pins
Cotter pins down to about 1/16" are fairly common and are available at most hardware stores, but smaller than that usually requires ordering them from model supply places. Making miniature cotter pins is a fairly simple task and does not take much longer than placing an order, and there is no waiting for them to arrive.
Clamp a piece of ground or cold finished steel in the mill vise, and then with C-clamps clamp a piece of wire to the plate as shown in the picture below. Use a wire of the size of the finished cotters. In this case I'm using a piece of .035"diameter nickel welding wire, although I've used other kinds with good results. It is just that these cotters will not rust.
Mill the wire down to one half it's diameter. It might move around a bit, but the steel will act as a backup. I usually clamp the wire at intervals of 3 or 4 inches to stabilize it a little, and stop and leap grog the clamps past the cutter as I come to them.
After milling the "D" shaped wire, de-burr it by sliding it through a folded piece of abrasive cloth a couple times.
Then using a short piece of the same size wire as the cotter, clamped in a vise, bend the D shaped piece around it and pinch it close to the form wire to shape the eye of the cotter.
After that snip it off and form another one, etc, etc. The length can be adjusted to suit the needs or simply snipped to length when they are used.
Shown here is an assortment of 75 that I made this morning. While it is not quite a hand full, it should keep me supplied for a while.
Birk
http://birkpetersens.blogspot.com/
Oldmechthings is offline
Old 05-03-2008, 06:20 PM   #2
Mcgyver
Liked 15 Times on 14 Posts
Default Re: Miniature Cotter Pins
I agree ordering stuff is a pita and who likes waiting. Is the wire under the end mill or between end mill and work?
Mcgyver is offline
Old 05-03-2008, 07:05 PM   #3
Oldmechthings
Mcgyver
I'm sorry, that picture could be deceiving. The wire is between the milling cutter and the the steel plate.
Birk
Old 06-11-2008, 05:50 AM   #4
sparky961
Sometimes it's the simple stuff that just makes you go "duh - why didn't I think of that?".
It's also just as easy to overlook the simple stuff and say "I'm sure someone's already thought of this", and the knowledge never gets passed on.
Thanks for the tip.
Pioneer Spirit - http://www.pioneerspirit.ca
sparky961 is offline
Old 06-11-2008, 03:43 PM   #5
I'll chime in here with a related observation.
Jewelers sometimes make half-round wire by winding the wire tightly on a mandrel and then turning away half the wire diameter in the lathe. Might be a bit easier than trying to mill the wire.
Tapered Pins and Bolts fltenwheeler Questions and Answers 5 07-04-2011 06:27 AM
Miniature tap wrenches gunboatbay Tools 0 04-06-2011 05:49 PM
Tapered Pins Brian Rupnow Questions and Answers 26 01-27-2011 08:35 AM
Roll Pins? kvom Tips and Tricks 6 08-27-2010 04:19 AM
engineering in miniature FIXIT Buy / Sell / Trade / eBay 3 08-18-2010 09:50 PM
