Home Model Engine Machinist > The Tools and Tips > Tips and Tricks > Cutting fins and piston ring grooves with a slitter saw
Old 11-15-2010, 02:01 AM   #1
JorgensenSteam
Default Cutting fins and piston ring grooves with a slitter saw
I use a slitter saw to cut piston ring grooves, but it should work equally well cutting fins on IC engine cylinders.
Old 11-15-2010, 02:17 AM   #2
Lakc
Liked 50 Times on 48 Posts
Likes Given: 14
Default Re: Cutting fins and piston ring grooves with a slitter saw
Thanks Pat.
There is a variety of reasons I did it the hard way this time. Next time will definately have more thought put into it. I am thinking perhaps 5 saw blades spaced and ganged together.
Lakc is offline
Old 11-15-2010, 04:55 AM   #3
Pat,
Do you cut them in reverse on your mill, or is this a set up shot?
Old 11-15-2010, 06:06 AM   #4
RichD
I think cutting in reverse is better since the chuck can't unscrew from the table spindle. I've never tried that yet.
Thanks,
Rich
RichD is offline
Old 11-15-2010, 06:55 AM   #5
No worries over it Pat, I was just curious, and what Rich says is a very good point.
You might have done it by mistake Pat, but it turned out OK and if you take into account what Rich has said, it was correct as well.
Piston Ring questions vcutajar Questions and Answers 12 05-23-2012 10:48 AM
Turning Retaining Ring Grooves ShopShoe Tools 14 04-17-2012 01:09 PM
Cutting cooling fins doc1955 Home Foundry & Casting Projects 9 03-09-2012 12:52 AM
Ring and Piston Clearance cobra428 Questions and Answers 2 08-15-2009 02:08 AM
Cutting cooling fins video deere_x475guy Photos and Videos 2 01-21-2008 09:16 PM
