Home Model Engine Machinist > The Tools and Tips > Special Materials > PTFE
Old 01-22-2010, 06:33 AM   #1
Mo deller
Default PTFE
I have a scrap box of plastic and was wondering if there is a positive way of identifying ptfe.
Peter
Mo deller is offline
Old 01-22-2010, 06:51 AM   #2
Noitoen
Liked 27 Times on 25 Posts
Default Re: PTFE
PTFE is a dull white, feels soapy, and is denser/heavier then other plastics.
Helder Ferreira from Setúbal, Portugal, (Europe)
Noitoen is offline
Old 01-22-2010, 08:07 AM   #3
rickharris
Liked 18 Times on 18 Posts
Default Re: PTFE
FWIW
Density PTFE (lb/in³)
unfilled 0.078 25% Glass filled 0.081 25% carbon filled 0.075
(g/cm³)
unfilled 2.16 25% Glass filled 2.25 25% carbon filled2.08
Same for Polyethylene
Density (lb/in³)
LDPE 0.033 HDPE 0.035 UHMW 0.034
(g/cm³)
LDPE 0.92 HDPE 0.95 UHMW 0.93
http://www.boedeker.com/ Useful site with lots of information
I am confused
rickharris is offline
Old 01-22-2010, 01:59 PM   #4
Mo deller
Default Re: PTFE
I have some that is I would say milky white and does feel a bit slippy to touch. I would guess it is ptfe but I have no experience so wondered if I could be fooled by something similar.
Rick, I dont know what to do with all the numbers. I guess there must be a formula to work it out from weight and volume but I have no idea how to do it.
Peter
Old 01-22-2010, 03:03 PM   #5
Noitoen
Default Re: PTFE
The numbers are easy. Just fill a graduated measuring cup with some water, drop a chunk of the material you want to measure, determine the water displacement in cu/in, weigh the piece and calculate the density.
Noitoen is offline
Old 01-22-2010, 04:15 PM   #6
Mo deller
Default Re: PTFE
Yes I can do the drop it in some water and weigh it bit,it's the calc I dont understand. What is the formula?
Old 01-22-2010, 04:56 PM   #7
Mo deller
Default Re: PTFE
Ok I think I have it. Mass divided by volume = density. I get the impression that's very basic and in reality it is more complicated.
Old 02-04-2010, 05:56 PM   #8
solver
Default Re: PTFE
How about simple rubbing-test? If it's ptfe, it should be quite slippery against for example brass or steel.
solver is offline
Old 02-04-2010, 11:56 PM   #9
charlesfitton
charlesfitton's Avatar
Likes Given: 44
Default Re: PTFE
A technican at my place of employ showed me a neat way to identify plastics
- a burn test.
Some won't stay lit, some smoke a lot, some drop small burning gobe of fire - I'm sure there's a chart somewhere on the web.
Marry up the characteristics with the chart and Roberts' married to your Auntie...
f
just getting older - not more mature
charlesfitton is offline
Old 02-05-2010, 01:24 PM   #10
Mo deller
Default Re: PTFE
I just had a google and found that if I poke a soldering iron into ptfe it doesn't drip and should smell of burnt hair.
Added to feeling slippery I think should get some positive id there.
Many thanks
Peter
PTFE in Flame-Licker t_ottoboni Questions and Answers 2 07-30-2011 04:17 PM
PTFE or Graphite Yarn packing? tmuir Questions and Answers 8 06-14-2010 03:48 AM
teflon (PTFE) martinbronsdon Questions and Answers 2 02-14-2010 04:58 PM
LTD stirling - PTFE or brass power piston instead of graphite? mnbylcr2 Questions and Answers 19 08-31-2009 07:18 PM
