Home Model Engine Machinist > Building Them > Engines From Castings > Westbury 'Seagull'
Old 05-08-2011, 10:21 PM   #1
Charles Lamont
Liked 16 Times on 13 Posts
Default Westbury 'Seagull'
Hello people. This is my first post in this neck of the woods. I live in the UK, West Midlands area. I have been doing model engineering for many years, but am currently tackling my first petrol engine.
It's a Westbury designed 10cc twin side-valve job, castings from Hemingway Kits 1.
You can see my progress (not very up-to-date atm, sorry) here: 2.
The latest problem I have with the design is the cam profile. As designed, the tappets are too small in diameter for
the cams, inlet in particular. As shown by plugging the dimensions into this brilliant resource 3, for a brief part of the motion, the cam is in contact with the edge of the tappet face, which seems unlikely to be good for either, or for noise (quiet is one of my criteria of success). Design dimensions are the same as the 'Seal': Base circle radius: 11/64", flank radius: 9/16", lift: 5/64" opening angle: 120°. I probably can make the tappets bigger, but ... any advice?
(1) http://www.hemingwaykits.com
(2) http://www.charleslamont.me.uk/Seagull
(3) http://modelenginenews.org/design/CamTable.php
Charles Lamont is offline
Old 05-08-2011, 11:29 PM   #2
Liked 406 Times on 293 Posts
Default Re: Westbury 'Seagull'
Well you have 3 options
(1) Make a larger diameter lifter. Great if you have room.
(2) Reduce the lift of the lobe. This will change the shape of the lobe and less diameter will be needed.
(3) Make lifters with a curved surface. If the surface of the lifter that contacts the lobe has a ball end or even any kind of radius you can run a smaller diameter.
If I think of anything else I'll get back here but thats all i have right now.
Old 05-09-2011, 02:50 AM   #3
RManley
RManley's Avatar
Liked 48 Times on 30 Posts
Hi Charles, very clear construction diary. How come everything looks so clean? I can tell this is going to be a very well made model by the time it is complete. Any ideas what you will use it for yet?
Also, where in the west midlands are you??
Rob.
Building a half size douglas motorcycle....will I be able to ride it? I just realised that a half height human is 3 years old....
Twitter: @ManleyEng
RManley is offline
Old 05-30-2011, 08:27 PM   #4
Charles Lamont
Thanks. After further exploration, there is also the possibility of a larger cam angle, allowing a 'softer' cam.
I have decided I will probably increase the tappets to 9/32", which I can just get in, even with a bush.
Old 05-30-2011, 08:39 PM   #5
Charles Lamont
Thanks, Rob
Does it? I clean parts before taking pics, but try to leave a bit of swarf around when showing setups.
Thanks again. No - no idea. I will need some kind of load to try it against, though.
Shropshire
Old 09-21-2011, 11:06 PM   #6
Charles Lamont
Default Lapping Timing Gears
Does anyone have advice to offer on lapping the timing gears together?
Old 09-21-2011, 11:47 PM   #7
lescad
In theory you can’t lap straight involute gears because they mesh with a rolling action, therefore there is no relative movement between teeth for lapping to take place.
In practice if the gears are mounted so that one can move from side to side you can sometimes improve things. With an idler setup like the seagull you would need to lap all three gears at once (moving the idler from side to side) so unless they really need it I wouldn’t bother.
Les
lescad is offline
Westbury Heinrici Stirling engine lazylathe Questions and Answers 14 09-26-2011 12:41 AM
westbury diagonal update imation Engines From Castings 4 09-21-2011 08:30 AM
westbury diagonalc paddle imation Engines From Castings 4 08-09-2011 08:39 AM
ET Westbury Side Paddle Engine kvom A Work In Progress 174 05-13-2011 10:55 PM
Dore Westbury Speedy Questions and Answers 1 06-19-2008 03:42 PM
