Home Model Engine Machinist > Building Them > Engines From Castings > Bottle frame steam engine
Old 08-08-2010, 06:00 PM   #1
Dan Rowe
Dan Rowe's Avatar
Liked 29 Times on 28 Posts
Default Bottle frame steam engine
Progress has been slow on this build but I have a couple of of cylinders done.
This is the metal wax injection mold with full steam passages. The injection point is rubber that I vulcanised in a bolt on part.
This is the other side.
The exploded view.
The port repair tool.
Test wax to show steam passages.
Bronze cylinder.
Dan
Dan Rowe is offline
Old 08-08-2010, 07:07 PM   #2
fltenwheeler
Liked 21 Times on 21 Posts
Default Re: Bottle frame steam engine
Hi Dan
That is a great looking injection mold. And the cylinder looks great too. I can not wait to see the rest of the engine.
Tim
fltenwheeler is offline
Old 08-08-2010, 11:49 PM   #3
4156df
Liked 26 Times on 26 Posts
Wow, Dan! Very interesting. Might be a dumb question, but is there some characteristic of this part that makes the port repair tool necessary? The tool looks like something you planned for in advance.
Dennis
Southern California, USA
4156df is offline
Old 08-09-2010, 12:57 AM   #4
Hi Dan,
Damn fine work!....I look forward to the rest of it too!
Old 08-09-2010, 01:00 AM   #5
Dan Rowe
Dan Rowe's Avatar
Thanks guys for the coments.
Dennis, yes the port repair tool was part of the plan. As this is a small cylinder the grid is 1/4" the way I made the curved port cores it did not leave much room for the gasket to seal the covers.
This is actually a 7/8ths scale Shay cylinder which is why there an extra mounting face. I plan to make a bottle frame engine first for a test.
Here is a photo of the port face, and the mounting face. I was having problems with the mounting face dishing in so I added the samll plate to make that section thinner which is exactly what the Lima Works did and where I got the idea.
The port cores are made from stacked sheet metal. The ports are 0.040" with the exhaust a double thickness and the bridges are 0.050"
The port core block has counter bored screws that act as stops so when the block is pulled out of the wax it only travels far enough to clear the wax model.
Dan
Dan Rowe is offline
Old 08-10-2010, 02:00 AM   #6
Dan Rowe
Dan Rowe's Avatar
Most of the machine work for the mold was normal with two interesting parts.
This is the fixture I used to file the holes in the mold end plates for the curved cores. The end plate fits in the slot on the base block and the center pin keeps everthing true.
To machine the ends of the port cores to have a curved end I made a hand powered belt sander with pneumatic feed.
Dan
Dan Rowe is offline
Old 08-10-2010, 12:59 PM   #7
Dan Rowe
Dan Rowe's Avatar
Pat,
Yes I used lost wax casting. The investment which looks like plaster of Paris is used to make the mold cavity for the hot metal.
Note: DO NOT use plaster of Paris for lost wax casting!
Here is a link to Abby's work in the specialist section.
http://www.homemodelenginemachinist.com/index.php?topic=4816.0
Here is a casting thread with some of the equipment used and a photo of my setup.
http://www.homemodelenginemachinist.com/index.php?topic=10197.0
Dan
Dan Rowe is offline
Old 08-23-2010, 04:38 PM   #8
manfred albert
Liked 33 Times on 24 Posts
Hello Dan,
a picture of a none finished bottel engine. A Friend of me is running a engine museum with original engines. About 80% of the engines in a running condition. In case You like information let me know.
manfred albert is offline
Old 08-23-2010, 10:50 PM   #9
Dan Rowe
Dan Rowe's Avatar
Manfred, Thanks for the photo. This engine is a freelance design from a few photos of the type and the one you posted is what I am shooting for.
Pat, mostly I use vulcanized rubber molds just like the jewelry trade. I never had any luck with a cylinder with a core for the bore only. The thicker section was caving in with both the wax injection and the metal casting. I finally went to a fully cored cylinder very similar to the original design and the shrinkage problems were solved because there were no longer any thick sections to cause problems.
The port repair tool fixes the end so a full cover gasket is used. There might be another way to core the steam passages but this is the simplest method I could come up with.
4 Jaw chuck (A)
4 Jaw chuck (B)
Bore cylinder.
Ream Cylinder.
Face end.
Trim cylinder rim with micrometer stop.
Trim and face other end.
More parts.
That is the project to date.
Dan
Dan Rowe is offline
Gerry`s Beam Engine with wooden frame geoff A Work In Progress 19 08-05-2013 09:42 PM
3D Bottle Engine JorgensenSteam Software and Programming 26 08-15-2011 01:02 AM
Need Help with PM Research Coke Bottle Engine SirJohn The Break Room 6 02-28-2011 07:41 AM
Bottle Engine JorgensenSteam Plans 0 08-24-2010 04:28 PM
Milling the main frame on the PMR #2A engine. Twmaster Engines From Castings 4 11-07-2009 10:34 PM
