Home Model Engine Machinist > The Tools and Tips > Metals > Nickel Aluminum Bronze (630)
Old 01-13-2009, 12:02 AM   #1
Default Nickel Aluminum Bronze (630)
So I lucked into a couple feet of 2.5" dia 630 bronze this afternoon (it had the tiger-striped look of bronze and was cheap, so I snagged it). How bad is it to machine on hobby-size tools (10-12" lathe, bench mill)?The web sites I've been able to find don't say much about machinability, which is usually a bad sign (one said 30% of 360 brass)... I was thinking of making things like flywheels from it if it's not going to be too cantankerous (I passed on a bunch of 304 stainless, remembering some poor reviews here)
Old 01-13-2009, 12:37 AM   #2
Liked 406 Times on 293 Posts
Default Re: Nickel Aluminum Bronze (630)
I have an el-cheapo 9X20 lathe and i have turned titanium, bronze, stainless, nickle. I would'nt worry about it.
Old 01-13-2009, 02:00 AM   #3
630 bronze cuts beautifully for larger parts.
When it gets too thin it becomes a little fragile to work with.
Old 01-13-2009, 03:28 AM   #4
Cool, thanks Rick. I guess I'll hang onto it then
At $20 for 18" of 2.125" round bar I figured it was worth a gamble at a Cedge-worthy scrap score
Old 01-13-2009, 09:07 AM   #5
jack404
Liked 9 Times on 9 Posts
like Rick said use WD40 or Kerosene to lube while cutting for nicer finish thats about all i can add
jack
jack404 is offline
Old 01-13-2009, 07:38 PM   #6
Kermit
Typical Uses
Industrial
Hydraulic Bushings for Earth Moving Equipment, Valve Balls, Bushings, Bearings, Heat Exchanger Flanges, Welded Piping Systems, Gears, Pump Parts, Condenser Tube for Power Stations and Desalting Units, Structural Members, Pump Shafts, Aircraft Parts, Valve Guides, Plunger Tips, Valve Seats, Shafting, Cams, Corrosion Resistant Articles, Balls, Heat Exchanger Headers, Tanks
Marine
Ship Propellers, Bolts, Nuts, Pump Parts, Propellers
Plumbing
Faucets
Old 01-13-2009, 08:36 PM   #7
I had to check the current price today at work.
2" 630 Bronze Rod is listed at $76/Ft
I'd say you found a deal there!
Upgrading to bronze from aluminum Swede Home Foundry & Casting Projects 4 03-30-2012 03:56 PM
Nickel plating deadin Questions and Answers 6 02-02-2011 02:00 AM
Need Nickel Silver rodbuilder Buy / Sell / Trade / eBay 1 02-10-2010 08:37 PM
plating kits including chrome, gold, nickel, copper, brass and many more. PTsideshow Links 1 05-08-2008 06:27 AM
Electroless (or electric) nickel plating. GeorgeGreek Metals 24 01-29-2008 09:48 PM
