Home Model Engine Machinist > Whats Left? > The Break Room > how do you clean your sharping stones
Old 05-20-2012, 11:49 AM   #1
dalem9
Liked 34 Times on 29 Posts
Likes Given: 29
Default how do you clean your sharping stones
How do you clean your sharping stones ,or do they not need to be cleaned. Thanks Dale
If you think you can,you can .If you think you can't you can't ! Were theirs a will their is a way !
dalem9 is offline
Old 05-20-2012, 11:52 AM   #2
Default Re: how do you clean your sharping stones
WR Smith "dresses" his stones by taping 150 grit wet/dry paper to a flat surface (he uses a surface plate...but I wouldn't subject my plate to that).
They usually wear hollow in the middle. This will flatten them out
He recommends hard arkansas stones....
Old 05-20-2012, 12:21 PM   #3
dalem9
Likes Given: 29
Thanks Dave
dalem9 is offline
Old 05-20-2012, 12:24 PM   #4
Dale :
I assume you mean a Arkansas oil stone. The best think to do is keep it clean use plenty of oil norton brand from the home depot works well. I have uses instrument oil but is harder to come by and more expensive. Wipe off the dirty oil after each use.
smiths recommends cleaning with soap and water after each use. scrub with a nylon brush.
and yes occasional lapping if needed to true them.
I have a couple stones that I have had for years I just use plenty of oil cant say I have ever used soap and water on them.
I came across this document a little OT but a classic worth a read
Norton Sharpening guide
Old 05-20-2012, 02:51 PM   #5
doc1955
Gone
Liked 43 Times on 42 Posts
How I clean and renew my stones (we cal them slips) is take a piece of scrap steel and a dab of lapping compound and lap the stone it will remove a small amount of stone and remove any material stuck on the stone, then a good cleaning with some denatured alcohol. After oil it back up and you are set with what should be and preform as good as brand new.
doc1955 is offline
Old 05-20-2012, 09:10 PM   #6
dalem9
Likes Given: 29
Thanks All Some good idea's . I would be afraid to use water because it freezes were I live . I have always wondered about this so I through I would ask . Again THANKS to ALL Dale
dalem9 is offline
Old 05-21-2012, 12:17 AM   #7
I think a little kerosene or Stodards Solvent (WD 40) would work just fine.
Old 05-21-2012, 12:44 AM   #8
HS93
HS93's Avatar
Being a Joiner by trade not a metal basher I leave my stones on the window cill and the odd day it is not raining in the UK and we get the yellow thing in the sky I find the warmth tends to make it sweat and it brings any deposits up to the surface, I then re oil with 3 in 1 oil a light machine oil, but this just help keeping it clean, not flattening for as you all know a good joiners stone is always flat . Yea !!!
Peter
how big a hammer do I need ?
HS93 is offline
But it will never be clean.. Lakc The Shop 7 06-23-2010 06:01 PM
Best way to clean copper BMyers Questions and Answers 2 09-01-2009 05:39 PM
how to clean up a commutator ? Mo deller Questions and Answers 17 08-13-2009 08:38 PM
Abrasive stones applescotty Tools 9 01-15-2009 12:03 AM
I just want my shop to clean itself up! BobWarfield The Break Room 2 04-30-2008 09:07 PM
