Home Model Engine Machinist > Showing Them > Photos and Videos > Rotary valve twin steam engine
Old 05-26-2010, 10:50 PM   #1
max corrigan
Send a message via AIM to max corrigan Send a message via MSN to max corrigan Send a message via Yahoo to max corrigan
Default Rotary valve twin steam engine
This is my rendition of the rotary valve engine in plans, i would like to thank whoever posted them it is a great little engine and runs well
My version was made from scrap cast iron,stock material, and anything else that fitted the bill
Here are a couple of pictures, then i will try the vids
Regards Max
Ps looks like the two attachments are of the same picture sorry!
max corrigan is offline
Old 05-26-2010, 11:36 PM   #2
Default Re: Rotary valve twin steam engine
Max,
That's one fine looking engine.
Old 05-26-2010, 11:48 PM   #3
HS93
HS93's Avatar
that looks great , what bore and stroke is it?
where did you get the plans for it
thanks
peter
how big a hammer do I need ?
HS93 is offline
Old 05-27-2010, 12:03 AM   #4
ironman
Liked 7 Times on 7 Posts
Beautiful finish on the parts. I built 2 of these. Even my sloppy first one runs great.
Really like your intake and valve. Keep up the good work and pictures. Ironman
Waco, Texas
ironman is offline
Old 05-27-2010, 12:55 AM   #5
SAM in LA
Liked 34 Times on 34 Posts
The dark color with the polished brass looks really nice.
SAM
SAM in Lower Alabama, USA
SAM in LA is offline
Old 05-27-2010, 02:30 AM   #6
Philjoe5
Philjoe5's Avatar
Liked 315 Times on 260 Posts
Likes Given: 52
Nice work Max. Great detail work. I like the black/brass combo.
Phil
Beware those who are often wrong, but never uncertain - B. Parker
Philjoe5 is offline
Old 05-27-2010, 04:06 AM   #7
Can anyone help me in locating the plans for this engine please?
Bogs
Old 05-27-2010, 09:12 AM   #8
max corrigan
A couple more pics
Peter HS93 the bore is 9/16" and stroke is 7/16
John (bogs) and Peter the plans are under "Elmers Steam Engine Plans" open page scroll down to Steam Engine Plans" (not Steam Engine Plans 2) scroll down on right hand side you will see Rotary Valve Engine
let me know if you get them
I'm gonner try the video in seperate post having trouble getting files in one post that's the problem not understanding computers
Regards Max.....
Old 05-27-2010, 09:16 AM   #9
HS93
HS93's Avatar
thank you for that I will have a look .
Peter
HS93 is offline
Old 05-27-2010, 09:48 AM   #10
max corrigan
I hope this Vid comes out OK, i first ran the engine on air, but steam gives it another dimension, I think!
The vid seems to show the engine running anti clockwise which is not the case, and the faster the revs the slower the valve linkage appears to move! very strange!
This engine can run at quite high revs, so much so, the grub screws i made (with slotted heads) flew out! hence the odd looking screws you might notice
i think i mentioned my bad steaming layout, you will see one exhaust blasting on the oiler which keeps it nice and hot! not quite the right idea idea
There were no leaks on the engine other than the ends of the valve rod, which were as in the plan, i put oil grooves on the pistons "alla Stuarti used 0 rings under the manifold, and tel's method for sealing cylinder head ie PTFE tape twined around head studs, no gaskets, as i said no leaks most of the steam is coming from the safety vale on the boiler and the exhausts
I did do a spasmodic build arrangement as i went along with pics, but now it would be retrospect but can attempt to post if anyone is interested
Regards Max
Overhead rotary valve twin dgjessing Plans 0 03-15-2012 07:20 PM
Rotary valve in-line twin (take two) dgjessing A Work In Progress 12 03-11-2012 07:04 PM
Rotary valve in-line twin dgjessing A Work In Progress 8 01-14-2012 10:29 PM
Rotary Valve Steam Engine rake60 Plans 18 10-15-2010 08:17 AM
Rotary valve twin esteam Photos and Videos 8 10-14-2009 01:39 AM
