Home Model Engine Machinist > Showing Them > Photos and Videos > Drag Saw
Old 04-15-2010, 10:41 PM   #1
putputman
putputman's Avatar
Liked 90 Times on 87 Posts
Likes Given: 16
Default Drag Saw
Well I finally got the drag saw to the point where it will saw logs. All of the hardware is rough finished but functional. Eventually I will disassemble everything and finish & paint it. My brother is cutting and planing some Red Oak for the frame. The final version should be somewhat shorter than this unit as I want to eliminate the large wooden box that contains the old Ford buzz coil. I'll be using a small CDI unit that can be hidden under the engine.
The size and speed is built around the large bicycle sprocket. It is the largest one I could find. 52 teeth. The drive sprocket is a 9 tooth that I made. It combination seems to give me a pretty fair speed and enough power so the engine will still hit & miss.
I went round & round on the clutch mechanism. Had many good suggestions from HMEM members. What I ended up with is kind of a combination of several ideas. It is more of a cog than a clutch. I felt I needed something positive that wouldn't slip under load. It engaged very well with the engine running but is a problem to disengage with any little load on it. I can live with that by stopping the engine after every cut.
The saw has about a 6" stroke which will allow me to cut a 5" log and still clear the teeth. Most of the information on the lever arm and eccentric was scaled off photos I got off the Internet. I also had some good help from "steamdave".
The blade is not what I want to end up with. It is very rusted & pitted. The tooth profile isn't quite what I want either. I have been watching Ebay and putting the word out in our tractor club for what I am looking for. I'll eventually get something better.
The full size unit sometimes have enough weight so they don't need anything to secure the log. This small unit required a log locking device. I made a small locking ratchet and mounted it to a frame that would secure the log in place.
Now a short video of it working. This is only the second cut, so anything can happen.
I was real happy with the performance of the Red Wing engine.
Thanks for watching
Arv
Brainerd, Minn. USA
Think twice -- cut once ---- www.putputman.com
putputman is offline
Old 04-15-2010, 10:53 PM   #2
Default Re: Drag Saw
I love it!
I've never seen such a beast but it looks like the sort of thing the old-timers would drag out to the forest to process firewood, etc..
One of the things I enjoy most is seeing these engines actually performing the tasks they were built to perform.
Great job.
Old 04-15-2010, 11:10 PM   #3
Liked 2275 Times on 2036 Posts
Nice job Putput!!! Is there any mechanism to lift the blade on the backstroke or is it full pressure both directions? ----Brian
Old 04-15-2010, 11:53 PM   #4
4156df
Liked 26 Times on 26 Posts
Putput,
Fantastic. I've seen some the old originals in museums, but never one operating. What a great project.
Dennis
Southern California, USA
4156df is offline
Old 04-16-2010, 12:04 AM   #5
putputman
putputman's Avatar
Likes Given: 16
Thank you for the comments.
Marv, this was used long before the chain saw. Here is a photo of one in use.
http://www.historicphotoarchive.com/capsmonner/monner4335.htm
Brian, it does not lift the whole blade on the return stroke. There is an eccentric on the lever that tends to lift the rear of the blade on the return stroke and pushes down on the forward stroke. Very similar as you would do using a hand saw, whether or not you realize it.
Dennis, I have seen a few of them at old farm shows. I never payed that much attention to them until I started this project.
Arv
Brainerd, Minn. USA
Old 04-16-2010, 04:37 AM   #6
te_gui
The air cooled were very common in the northwest, the hopper cooled ones are much less common. Many of them were 2 cycle so you have to be careful when you start them that they are running the right direction. Since they cut on the pull stroke, running backwards tends to throw the blade back at you when you drop them into the log. They also made steam powered ones to cut wood for logging donkeys
Brian
te_gui is offline
Old 04-16-2010, 06:54 AM   #7
Noitoen
Liked 27 Times on 25 Posts
The engine has a nice PutPut sound Man Cool
Helder Ferreira from Setúbal, Portugal, (Europe)
Noitoen is offline
Old 04-16-2010, 04:18 PM   #8
m_kilde
Liked 9 Times on 9 Posts
I love it too
Really a put put - great show
Thank you for sharing
Mogens Kilde
http://m_kilde.skysite.dk
m_kilde is offline
Old 04-16-2010, 04:55 PM   #9
Diy89
Very sweet runner! My father talked about these types of saws long ago.
Diy89 is offline
Old 04-17-2010, 12:53 AM   #10
putputman
putputman's Avatar
Likes Given: 16
Thank you for your comments.
Brian, you sound like you have some experience with drag saws. I have only seen a few in operation at farm shows. They are somewhat slow but are steady. They beat the heck out of cutting by hand.
Diy89, did your father use the drag saw? Maybe you have some photos you could share with us.
Arv
Brainerd, Minn. USA
