Home Model Engine Machinist > The Tools and Tips > Tools > Wabeco F1200E Milling Machine
Old 10-09-2008, 03:14 PM   #1
kellswaterri
Default Wabeco F1200E Milling Machine
Hi folks, anyone have experience or comments on the above.
John.
kellswaterri is offline
Old 10-09-2008, 07:29 PM   #2
Florian
Liked 24 Times on 24 Posts
Default Re: Wabeco F1200E Milling Machine
Hi John
german product (no chinese rubbish)
aehm.. I know a guy who has one and he's totally happy with it. I also looked at these machines on a fair and it looks quite good. Of course, you can't compare it with a professional milling machine but for hobby its a good machine. The only weakness is the speed controller of the electric motor. If you want the rpm to be constant, its recommended to either buy the High speed version with frequency inverter on the basic configuration or to replace the standard motor and to put a three phase motor with frequency inverter. I would do this when the speed controller breaks down the first time. (This sometimes happens. But there are lots of guys having a wabeco for years with no speed controller damage..)
Florian
Florian is offline
Old 10-09-2008, 09:25 PM   #3
kellswaterri
Hi Florian, this is the one issue which I will have to be assured about '' the speed controller''...as I work with cast iron quite a lot I want to see if the controller switch is sealed from dust ingress...also how often breakdowns due to the speed controller have occured...now who is going to tell me that
All the best for now,
John.
Old 10-09-2008, 10:22 PM   #4
CrewCab
Liked 31 Times on 31 Posts
imho I would doubt it John, but I suspect a bit of silicone sealant would probably sort that out.
Got to say though, if the CI dust is such a problem I'd be thinking more along the lines of "extraction" ........... cos we all need you to be posting in 2009, 2019, 2029 .......... etc
CC
CrewCab is offline
Old 10-13-2008, 04:24 PM   #5
Florian
Hi john
i'll have a look at the switches on the mill when i visit that guy next time.
If you want to work with cast iron, you may need to use a vacuum cleaner to directly clean away any dust.
Florian
Florian is offline
Old 10-15-2008, 05:56 PM   #6
Davidh
John.
Lovely machine. I wouldn't call it a hobby machine but a small 'real' mill.
Re dust. There is no fan or forced vent so dust is not circulated through the pcb& switch.
The switch is a generic NVR start stop. If it gets smoked you change it.
Yes, the spindle speed is not feed back governed. This presents no problems.
5year warranty. There is some nice ones cnc at youtube.....
David
Davidh is offline
Old 10-15-2008, 09:14 PM   #7
kellswaterri
Hi all,...more or less decided to go for the F1210E with bigger table...[1200 might just be too small a table]...all reports on these machines have been very positive to date...thank you all for your input.
John.
Milling machine nsfr1206 Tools 11 12-02-2011 12:18 PM
XJ 25 Milling machine kendo Questions and Answers 0 07-20-2010 10:38 AM
AMA25LV Milling Machine Omnimill Tools 32 02-23-2010 12:09 PM
Looking for a milling machine mcr Buy / Sell / Trade / eBay 2 10-31-2009 07:24 PM
New Milling Machine Oldmechthings The Break Room 6 09-10-2008 09:40 PM
