Home Model Engine Machinist > The Tools and Tips > Tools > Some info for any using the series 222 plastools carbde insert 3/8" tool bits.
Old 05-11-2012, 12:58 PM   #1
PTsideshow
PTsideshow's Avatar
Liked 18 Times on 18 Posts
Default Some info for any using the series 222 plastools carbde insert 3/8" tool bits.
A number of years ago, before Sherline started offering tool bits to hold inserts. I bought a set of 3 tool bits from Plastool Plastool They use the cheapest in cost insert TNMG-222 since that style seems to be the most popular. I just bought 15 of the for under $15.00. The tool bits had a funny looking .05 Cap screw head, not really a button head and not a standard head. At the NAMES show I recently bought the QC tool post set up with two 3/8 tool bit holders. I had always been concerned about dropping/loosing the screws.
I contacted the new owners of the company, as the ME that designed and made them has gone on to the large shop in the sky!
They got back to me with some info. The screws are standard 2-56 button heads, what he did say is that they grind the heads down to a smaller dia for a better look.
I went out and bought a bunch of the screws, so Now I don't have to be concerned about the funny looking heads on the insert hold down screws.
They have other sized insert tool bits. in addition to the Sherline, Taig, Unimat,Prazi
They work well, and a economical alternative if you don't have a carbide sharpening set up.
Glen
1st license stationary engineer ret.
All the usual and standard disclaimers apply. Do not try this at home, use only as directed, No warranties express or implied, for the intended use or the or the suggested uses, Wear safety glasses.
PTsideshow is offline
Old 05-11-2012, 01:05 PM   #2
kuhncw
Liked 22 Times on 22 Posts
Default Re: Some info for any using the series 222 plastools carbde insert 3/8" tool bits.
Hi Glen,
Thanks for the tip on the Plastools screws. I have a set of these insert holders also.
kuhncw is offline
Old 05-11-2012, 10:24 PM   #3
Mosey
Liked 41 Times on 37 Posts
Likes Given: 12
I get mine from Enco, no name, Chinese. The cost for a set of 5 holders with cutting inserts is less than the cost of the replacement inserts alone. They tell you that the holders come without inserts, but that's not so.
Mosey is offline
Old 05-18-2012, 11:13 PM   #4
clivel
Liked 13 Times on 10 Posts
Having bought a Unimat lathe some years back (which I only started actually using a few weeks ago), I took to trawling eBay for Unimat accessories which is where I came across Plastools.
From the eBay listing I noticed that Plastools were located in Bellingham a town I passed through every Friday afternoon on my weekly commute home from Seattle to Vancouver. So, being a complete novice and not knowing what tools would best suit my needs I emailed Plastools to ask if I could pick up the tools directly.
On receiving a positive reply and directions to his rural home from professor Hackler the then owner/founder of the company I decided to pop in the following week.
I spent a pleasant hour or two with the professor who very kindly showed my around the workshop where he actually manufactured the tools, and spent far more time than he need have explaining about tool types, cutting angles and the rationale behind the Plastools design, most of which went completely over my head.
But that does eventually brings me to the point of this long rambling story. I distinctly remember him telling me that he only used high tensile screws that he imported specially from a company in Switzerland for holding the insert. That is not to say that the present company (now owned by his son I believe) still does however.
Clive
clivel is offline
IHS - any info on users of this company's "Haystack" service David Morrow The Break Room 0 12-14-2011 03:52 PM
Atlas/Craftsman 6" lathe 214 series gear chart jgarrett Tips and Tricks 0 03-08-2011 01:20 PM
Making a Phase 2 QCTP 100 Series Tool Holder jamesemery728 Tools 8 01-29-2011 03:17 PM
Insert Parting Tool Omnimill Tools 13 12-24-2010 01:33 PM
Indexable bits info needed jgarrett Tools 42 01-26-2008 12:00 PM
