Home Model Engine Machinist > The Tools and Tips > Tools > Sherline, Microlux or the Taig lathe/mill?
Old 03-06-2010, 11:22 AM   #1
shlomo
Default Sherline, Microlux or the Taig lathe/mill?
Hello all,
I bumped into this excellent forum while I was looking for information on building engines (lucky me ha?). I must admit that I was very impressed by the quality of the work here.
I have several questions I hope someone can help me with. Please understand that I am new to this, I initially intended to buy a woodworking lathe, since I am now working mostly with hand tools on wood.
Then I was exposed to the metal milling/turning world and started reading and was enthusiastic about it (making engines, clocks etc) . I am trying to decide now what would be best for me a lath or a mill and from which vendor (Micromark, sherline or taig) and which one can work well with wood as well as metal.
Do you think a lathe would be more suitable if you are new to this sort of work?
I am especially interested in making a small (steam?) engine, from a plan, without using a CNC machine.
I looked at these:
Taig:
TAIG-2019CR-ER (http://www.super-tech.com/root/itm.asp?p1=itm-Taig-Mills )
Micromark:
http://www.micromark.com/MICROLUX-7X14-MINI-LATHE,8176.html
http://www.micromark.com/MICROLUX-BENCHTOP-MINI-MILLING-MACHINE-ALL-INCH-MINI-MILL,8102.html
and of course Sherline which is available in my country (Israel) without the need to ship internationally.
Any comment would be appreciated especially from those who own any of these machines and used it to build their first engine. would this http://www.steves-workshop.co.uk/steammodels/simpleoscil/simpleoscil.htm be considered a good first project?
Another question i have is, do any of you use CAD software such as AutoCad even if your mill is NOT CNC ready?
Thanks,
Thanks and have a wonderful weekend,
Shlomo.
shlomo is offline
Old 03-06-2010, 11:39 AM   #2
b.lindsey
b.lindsey's Avatar
Liked 62 Times on 61 Posts
Default Re: Sherline, Microlux or the Taig lathe/mill?
Hi Shlomo and welcome to the forum. I am sure you will get lots of responses as to the various machines out there. Personally I use sherline and have for 12+ years and like them very much. I have both the lathe and mill and neither is CNC. If they are available in Israel I would think that is a plus, but with any of these smaller machines you do need to think in advance about the types of projects you want to do, not just now but in the future as their size can be a limitation. Think also about the tooling and accessories you will need in addition to the basic machine(s). Again I find one advantage with Sherline in that there are many quite useful Sherline accessories available which work seemlessly with their equipment
As for CAD, I use AutoCAD LT 2007 for 2D drawings to work from, but also have access to SolidWorks at work when needed.
Bill
skype: william.lindsey.iii
b.lindsey is offline
Old 03-06-2010, 12:13 PM   #3
Liked 627 Times on 506 Posts
Shlomo:
Any of the listed machines would work well to set up a model engineering shop. and all should have decent availability of accessories and tooling.
Sherline is top notch made in USA.
Taig imHO is also another good made in USA brand I do not think quite as popular as the Sherline.
The micro mark brand is Chinese import and should be available in your part of the world with a different paint color and label.
These machines are made bySEIG
These machines are quite popular .I started with these types of machines and still use them.
If you want to learn single point threading the seig lathe is the only one that will thread out of the box. the others need add on tooling.
as far as cad this software http://www.alibre.com/products/ is quite popular here and value priced. it is what I use although i do have a lot to learn with it.
Print out the scec sheets for each machine and compare what you are, or are not getting with each one. what features are important to you ? Then ask questions. each of those machines will have some advantage and disadvantage compared to the others.
Learn manualy but all of the above can and have been converted to cnc . cnc ready with manual handles for now is a nice feature.
Old 03-06-2010, 01:08 PM   #4
I've got a Taig and it's a nice quality small mill. The lathes are roughly the same size as the Sherline, but the Taig mill is a little larger, though the Sherline has more attachments. I've seen super nice work come off both (some posted here), so it may come down to availability and parts and support that decides it for you if you like the work envelope.
Most people these days seem to start with a lathe then obtain a mill fairly soon thereafter, although in the 'old days', home shop mills were fairly few and far between; my copy of "The Amateurs Workshop" says it was unlikely to have a mill in an English hobby workshop circa 1950. I think they did a lot more filing in those days.
Old 03-06-2010, 01:44 PM   #5
zeeprogrammer
Liked 170 Times on 170 Posts
Welcome to the forum shlomo.
I started this hobby about a year ago with no experience.
I have the blue Seig mini-lathe and an X2 mill. I'm pretty happy with both but they do need some care and adjusting...especially the lathe.
But the lathe/mill is only half the equation. Be sure to investigate accessories and tooling. They represent an investment that could equal if not exceed the cost of the machines.
Think about what projects you want to do in the future and whether the machines will be capable. Size of part is a big factor.
To work. To work.
zeeprogrammer is offline
Old 03-06-2010, 01:57 PM   #6
bearcar1
Liked 42 Times on 42 Posts
Greetings Shlo,
I believe that if Sherline is available in your country that in order to save any VATs or other unforeseen duties, shipping charges etc., that would be my choice in the matter. The other machines are decent, I also am a fan of the Taig, but I chose Sherline when I started out and still have their lathe and mill and it is high quality and the accessories are endless. This of course is just my opinion and I am sure that you will make a educated decision that will bring you a lifetime of machining pleasure. Again, welcome to HMEM.
BC1
bearcar1 is offline
Old 03-06-2010, 03:47 PM   #7
D.C.Clark
I strongly recommend Sherline. Join the Sherline forum at:
http://tech.groups.yahoo.com/group/sherline/
Dan Pines, a Sherline distributor in Israel, is a regular participant. Drop him a line, drop my name.
I am occasionally tempted to get a Sieg machine. All I have to do to talk myself out of it, is to monitor some of those forums for a few days, and read all the horror stories.
David Clark in Southern Maryland, USA
D.C.Clark is offline
Old 03-06-2010, 06:59 PM   #8
shlomo
Thanks to all the participants who replied to my questions, I really do appreciate it
This is the sherline model I am now considering: http://www.sherline.com/images/4000Cpic.jpg
So if I understand correctly the Lathe would by sufficient to construct lets say this beginners model?:
http://www.john-tom.com/ElmersEngines/23_ElmersTiny.zip
Do you think there is really a need for the longer Sherline version (e.g. http://www.sherline.com/images/4400Cpic.jpg) ?
Once again, thanks,
shlomo is offline
Old 03-06-2010, 07:55 PM   #9
Shlomo,
Welcome to our forum.
Old 03-06-2010, 09:35 PM   #10
vlmarshall
vlmarshall's Avatar
Liked 55 Times on 55 Posts
Send a message via Yahoo to vlmarshall
Welcome to the forum! I don't know what sort of parts you plan on turning... but I bought the 4400 Sherline last month.The majority of parts I'll be making won't need the long bed length, but when I do need it, I won't have to go hunting for another lathe.
Cranking that table all the way down the bed takes FOREVER, though.
Chesapeake, Virginia, USA, Northern Hemisphere, Earth, Sol system, Orion Spur, Milky Way.
Sherline 5400 mill, Xylotex drivers and EMC controller
Sherline 4400 lathe, Gecko drivers and EMC controller
vlmarshall is offline
How many on here use a Taig / Peatol Lathe or Mill? alan2525 Tools 15 10-27-2013 10:32 PM
Some questions about a Taig mill jdsackett Questions and Answers 9 04-10-2011 02:34 PM
sherline 5400 and taig lathe dro's Speedy Questions and Answers 0 08-04-2010 02:45 PM
Dividing head for Taig lathe/mill joe d Tools 61 01-17-2010 02:32 AM
Tramming a small mill (Sherline mill) ttrikalin Tips and Tricks 9 11-22-2009 05:58 PM
