Home Model Engine Machinist > The Tools and Tips > Tools > New (to me) chuck, and making a backplate
Old 03-29-2012, 04:43 AM   #1
smfr
Liked 26 Times on 26 Posts
Default New (to me) chuck, and making a backplate
I'm sure this is all old hat for you experienced machinists, but this was only my second chuck backplate that I've made so a couple of things had me scratching my head.
So I got a pretty good deal on this Bison 5" 3-jaw on eBay:
and you can see beside it the backplate that I ordered. My lathe is a 1962 Emco Maximat "Standard", which has a Myford-style spindle thread: 1 1/8 12TPI. Now backplates with that thread are as rare as hen's teeth in the US. Bob at New England Brass and Tool can supply one, but for $155! So I went with Arc Euro Trade in England, and got two for £16 each, and with shipping it was still only about $100. They are a nice fit on the spindle nose, too.
Once the backplates arrived it was time to turn one down for the chuck. I skimmed the face, then turned down the edge about 1/8", leaving a boss in the middle which was a close fit to the chuck body. I managed to get a nice fit. The steel of the backplate machined very nicely, leaving some pretty blue chips:
Now the next part was to locate the bolt holes. I don't have a DRO, and since the backplate has a hole in the center, it's tricky to mark out with dividers. So I ended up sticking a bit of Al sheet over the center with superglue. Then a small tap on that with a center drill gave me a center I could work from:
Next problem. Machining the backplate had tightened it on the spindle pretty well, and there was nothing to grab onto to get it off! That required a trip to the hardware store to get a strap wrench which did the trick!
For marking out the bolt holes I got the hole pattern from the Bison documents (54mm radius), and used dividers to mark that radius in six spots around the edge. The center point is raised above the edge by just over 1/8", but some quick math showed that it wasn't necessary to worry about how that affected the radius I just marked out. Then, without changing the dividers, I marked off six divisions around the circumference of the scribed circle; that marks off a hexagon, so the alternate points give me the 3 bolt hole locations.
I then clamped the backplate down on the milling table and drilled the 3 holes, cleaned up the burrs, and tested the fit. It was good!
And finally the acid test: how bad was the runout?
I get a max of 0.0012" (after zeroing on the opposite site, which I assume is the normal way to measure TIR?) , which I'm pretty happy with. I also checked the steps on the jaws, and they seem quite accurate, which is better than my Bison 4-jaw.
smfr is offline
Old 03-29-2012, 06:40 AM   #2
mzetati
Liked 22 Times on 22 Posts
Default Re: New (to me) chuck, and making a backplate
I'd have marked the bolt circle using the cross slide dial, having it zeroed when a pointed tool (scriber) was aligned with a center set into the spindle.
Marcello
mzetati is offline
Old 03-29-2012, 07:52 AM   #3
I have used those very same backplates, and can attest that they do machine and fit very nicely indeed. I use them for my interchangeable tooling between lathe and mill.
I always drill my mounting holes 0.5mm larger, just to make sure there are no binding forces acting on any part of either the backplate or chuck, and your final runout is about the norm for self centering chucks. In fact anything up to about 0.003" is about right, unless you can get hold of very expensive or truing types.
If it is up to your expectations after the job is finished, then it is a job well done.
Old 03-29-2012, 10:28 AM   #4
lazylathe
lazylathe's Avatar
Liked 24 Times on 24 Posts
Send a message via MSN to lazylathe
Nice and informative for me!!!
I have often wondered about how to go about fitting a backing plate.
You make it sound easy!
I will have to give it a go one of these days!
Andrew
The best part about procrastination is that you are never bored, because you have all kinds of things that you should be doing.
Time is money, money is the root of all evil, and knowledge is power. Therefore, procrastination is the key to world peace.
lazylathe is offline
Old 03-29-2012, 11:21 AM   #5
lordedmond
do as John ( bogs ) has said but reduce the register a little bit about 5 thou
then put in a test bar of your most used size of stock slack off the bolts a tad tap thae chuck with a hide hammer until true nip up the bolts , your own set true 3 jaw
nice work BTW
Stuart
lordedmond is offline
Old 03-29-2012, 12:31 PM   #6
Just as an aside, I also used one of those cheap backplates to make a clamp plate for my rotary table, which also now has a Myford nose on it.
http://madmodder.net/index.php?topic=2002.msg22748#msg22748
But it could easily have been used on the lathe instead of a faceplate or drive plate.
Old 03-29-2012, 01:54 PM   #7
.0012" is great for a 3 jaw! That'll work just fine.
It will be different with the jaws at different diameters, but that's to be expected from a 3 jaw.
If you want the limit of runout, then you need a 4 jaw or good collets.
Great Score!
Old 03-29-2012, 07:20 PM   #8
Hopefuldave
Likes Given: 14
If you have the register for the chuck turned to size (I usually go a little on the tight side), marking the bolt locations is easy - You need Transfer Screws
Take a few capscrews the correct thread for the chuck, and turn or grind to a point (it needs to be nicely concentric with the screwthread) then file or grind a pair of flats on the pointed ends so you can grip 'em with a pair of pliers - then cut off the bolt heads and clean up the threads, screw them into the chuck so about 1mm / 40 thou" of the point is projecting, marry up chuck and backplate and administer a thump with a mallet / deadblow hammer - hey presto, three (or however many you need) centre-punch marks on the axis of the screw holes in the chuck.
Much, much easier than trying to mark out the hole locations, and a damn sight faster. Works well when you need to mark out a cover for an existing part, too!
My Grandad (a toolmaker) taught me this, as I sat on his workbench, aged 10...
Dave H. (the other one)
Hopefuldave is offline
Old 03-29-2012, 08:05 PM   #9
gmac
Liked 22 Times on 21 Posts
smfr;
How long did it take to receive the order from Arc Euro Trade? How were they shipped? Like you I balked at the price for a ready made chuck adapter on this side of the pond, but at that price for two....hmm. Thanks for the post!
Garry
British Columbia, Canada
gmac is offline
Old 03-29-2012, 08:24 PM   #10
krv3000
HI a job wel dun
krv3000 is offline
Collet chuck and backplate kevincoxshall Questions and Answers 12 07-11-2012 08:06 PM
New ER32 chuck backplate mzetati Tools 5 05-11-2011 07:10 AM
Myford ml7 chuck backplate. firebird Questions and Answers 6 10-20-2009 08:46 PM
Making a threaded backplate for chuck? dieselpilot Questions and Answers 2 08-21-2009 10:30 AM
Making a Backplate for a Collet Chuck BobWarfield Tools 15 08-08-2009 12:46 AM
