Home Model Engine Machinist > The Tools and Tips > Tools > DIY electronic Z-axis zero setter
Old 06-10-2009, 10:43 AM   #1
Majorstrain
Liked 13 Times on 12 Posts
Default DIY electronic Z-axis zero setter
This is a small off shoot from making the QCTP. You how it goes, make a tool to make a tool to make a project. I'm waiting for the dovetail cutter anyway.
The electronic parts and cost under $10 and the spring I got from an auto shop for $2.50. All the steel is of unknown grade out of the scrap box, you could use ali for all but the top button.
I changed the body size 35mm on mine because that was all I had. The consequence of the reduction was to use M2 screws to hold the base on instead of M3
The Teflon plumbers tape is thicker than the standard but you can use whatever you like. The drawing also mentions a solder tab but I didn't need them in the end, I just wrapped the wire round the screw.
The final height does not have to be accurate, all you do is measure it and use that figure as you z-axis offset. Mine turned out at 25.08mm
Here is the drawing for the project
Enjoy
Phil
stand by for pics.
Majorstrain is offline
Old 06-10-2009, 11:09 AM   #2
Majorstrain
Default Re: DIY electronic Z-axis zero setter
Here are the assembly pics, I didn't take machining pics because it's all standard stuff.
If something is not clear just ask and I'll mock up the set-up for you.
These are the parts,
The buzzer is a 3 to 15 volt DC type
The pack with the grey and white bits are a TO-3 transistor insulating kit. You only want one of the white bits (insulating sleeve)
The plumber thread seal tape is 0.1mm thick (not critical)
The other parts are a standard 9V battery and a battery snap.
This is the spring I got from the auto store, it was 100mm long and had a diameter or 15mm. I is quite stiff.
I heated and cut it at 20mm and then bent it to form a flat bottom and ground the base level.
The springs free length ended up to be 15mm long and the cavity space is 12.9mm so there is a bit of force on the button holder when assembled. This is what you want.
The following pics are the assembly steps
The wire was and old USB cable that I cut the ends off and used two out of the four wires.
The black wire is sandwiched between the button holder and the insulating sleeve cap.
The red wire attached and seated
The top button wrapped with one layer of Teflon tape. Use two or more layers if you have the thin tape.
The button installed in the button holder. I ran a blade around the tape to trim off the excess.
The inside view as assembled.
Finished the assembly. now to show the wire connections.
Well that's it
Phil
Oops, forgot to explain how to use it.
Just sit the Z-axis zero setter on top of your part and raise the mill knee or lower the spindle until the stationary cutter contacts the button top. when contact is made the buzzer will sound. Then just set your DRO to minus (or plus, depending on your DRO) the height of the Z-axis zero setter and use that as you offset above the job.
Note the Z axis DRO readings
It could be used on the lathe as well, but you would have to hold it in place on the part face with you hand while you touched the tool tip to it.
The button is spring loaded so if you contact it with a bit too much force, it won't get damaged.
Old 06-11-2009, 11:34 PM   #3
Liked 627 Times on 506 Posts
This may be a realy dumb question but how is contact made inside . I am not quite seeing how this works.
Tin Falcon is online now
Old 06-12-2009, 12:54 AM   #4
Majorstrain
Hi Tin
There are no dumb questions, if 1 person is asking then 20 other people are thinking it.
There are no contacts inside. The Teflon tape forms an insulator between the two wires and the metal they are attached to. The electricity requires another path to flow and make the buzzer sound. This other path is the body of the mill or lathe itself.
The contact is made (or for a normal circuit the switch is closed) by the cutter or tool tip through the machine body. (mill or lathe)
When the cutter touches the top button of the zero setter the circuit is completed and the buzzer sounds, without the cutter touching the zero setter the circuit is open and the buzzer is silent.
The path the electrical current takes from the battery is through the red wire to the top button of the zero setter, from there it flows through the cutter and machine body to the machine table and part to be machined.
It then flows through the zero setter base to the button holder and back through the black wire (note below) to the buzzers red wire, from the buzzer it flows back to the battery in the black wire.
So in effect there is no moving contact inside the zero setter. The only moving part is the spring and its only job is to absorb the pressure of the cutter touching down too hard.
The correct offset reading is taken when the buzzer just starts to sound on application of the cutter.
If the spring has been compressed by the cutter touching down too hard, the the reading is taken when the buzzer stops sounding on withdrawal of the cutter.
Note: If you're machining a non-conductive material like PTFE of PVC the the current can not flow back through the part being machined. to get around this I mounted my buzzer and battery in a metal box (jiffy box) and connected an extra wire to the point where the black wire from the button holder and the buzzers red wire are connected. Then I connected that extra wire the the metal box. So as long the metal box is resting on the machines metal surface somewhere then there is a return part for the current to flow.
Sorry for the long winded reply, I hope I've covered it.
Phil
ps the above explanation assumes conventional current flow theory as opposed to electron flow theory.
Old 06-12-2009, 10:27 AM   #5
Now I see said the blind man LOL
The button is one contact it is insulated from the body the body the other contact the mill is the switch. Where is the blinky L.E.D for those who can't hear the buzzer.
Realy I do like this project and will likely buiild one for the cnc mill.That is after I tranlate to american LOL.
Old 06-12-2009, 11:16 AM   #6
Majorstrain
Thanks for the comments and questions Tin,
Google translate does a pretty good job.
Phil
Interesting tool bit setter Jeremy_BP Buy / Sell / Trade / eBay 13 01-04-2012 11:41 PM
Electronic Ignition Help !!!! mh121 Questions and Answers 5 10-12-2011 10:05 AM
ELECTRONIC GADGETS drallen The Break Room 29 04-04-2011 12:27 AM
Bogs goes electronic. Blogwitch The Break Room 42 07-30-2010 03:23 PM
Electronic hobber John S Tools 6 10-04-2008 03:38 PM
