Home Model Engine Machinist > Building Them > Plans > Lathe and Mill plans (home made making mini lathe and mill)
Old 01-23-2013, 05:38 AM   #1
alihureiby
Liked 12 Times on 6 Posts
Send a message via Yahoo to alihureiby Send a message via Skype™ to alihureiby
Default Lathe and Mill plans (home made making mini lathe and mill)
this's is about 7-10 mb, so i can's upload here because the max limit is 3 mb.
if you want just email me on al_hureiby@yahoo.com , i will attach you by email.
i got the URL site
http://mmu.ic.polyu.edu.hk/il/Haesls/2011HaeslLathe.pdf
some pict of the plans.
alihureiby is offline
6
Old 01-23-2013, 09:43 AM   #2
Herbiev
Herbiev's Avatar
Liked 87 Times on 82 Posts
Hi Ali. Quite an ambitious project you got there. Looking forward to following your progress.
Herbie
Hallett cove
South australia
Herbiev is offline
gus Likes This
Old 01-23-2013, 12:22 PM   #3
Omnimill
Liked 36 Times on 32 Posts
Likes Given: 33
I've thought about this several times. Although more expensive I'd use Linear guides rather than rods and bearings:
http://www.directindustry.com/prod/kml-linear-motion-technology-gmbh/linear-guide-rails-63228-481935.html
They use these on specialist machines quite a lot.
Omnimill is offline
Old 01-23-2013, 12:41 PM   #4
RonGinger
RonGinger's Avatar
Liked 41 Times on 36 Posts
Many years ago MODELTEC magazine had an article on a small lathe that was very easy to build. Its way structure was 1" square ground stock set on point so it made 45 degree V ways. The entire design was very clever.
I would avoid round ways. It is impossible to make any adjustment for wear. With a V way the gib or lower member can be tightened to take out slop. I would seriously consider the ball slides.
I think I have the old issue in a box, Ill dig around and see if I can find it. I dont know what the copyright issues would be, the magazine has been defunct for years.
RonGinger is offline
Old 01-23-2013, 01:55 PM   #5
alihureiby
usually that bearing rail is used for smoth move machine like cnc router/engroving. but for lathe and mill which must handle more weight that's will not long life.
like RonGinger say, for lathe is V way is good.
but it's look nice and expensive, im trying to build my home made cnc engroving but i use bearing locker rail (this is for trail so use cheaper one)
Old 01-23-2013, 01:58 PM   #6
alihureiby
hii
yes you right, but it's need casting level
ali
Old 01-23-2013, 02:00 PM   #7
alihureiby
hi
nooo, just sharing that plans
Old 01-23-2013, 03:36 PM   #8
TorontoBuilder
TorontoBuilder's Avatar
Liked 19 Times on 15 Posts
Copyrights extend past the life of publication or company, or the life of the original rights holder. Companies that go bankrupt usually have their creditors seize their copyrights. Copyright holders who die either will their copyrights to another person or if not specified the rights pass to next of kin.
In the case of Modeltec I believe the rights were sold to Daniel Smith of Louisville Kentucky. So it would be best not to post a copy here, as much as I would like a copy.
However, if you find the issue number I'd appreciate knowing the issue so I can try to buy an old copy of that issue of the magazine. I cannot find the article in my index of Modeltec magazine. Failing that I would try to contact Daniel to see if he has a copy for sale or would grant permission to authorize the copy of one.
TorontoBuilder is offline
Old 01-23-2013, 05:44 PM   #9
Omnimill
Likes Given: 33
Originally Posted by alihureiby View Post
We recently sold a Denford CNC Milling Machine at work (about the size of an X3) that had exactly that type of linear bearing! If it's good enough for Denford I'm sure it would be fine for my needs.
Omnimill is offline
Old 01-23-2013, 08:52 PM   #10
RonGinger
RonGinger's Avatar
I have dug through my old MODELTEC and cannot find the lathe article. I remember it was a design project by a College course. It used machining of related parts clamped together- like the left and right legs and the headstock so that the cuts for the square ways would be exactly the same distance apart. I think it was the cover story of the issue with a photo on the cover.
Sorry I cannot find it now. Maybe someone else that has more MODELTEC than I do can look.
larry1 Likes This
Mini Lathe / Mill Oil Fittings jtrout13 Questions and Answers 1 09-03-2012 12:42 PM
best mods for 7x10 mini lathe & mill what's yours? sourdoughsmitty Tools 21 01-19-2010 03:25 PM
Mini Mill and 9x20 Lathe For Sale Jack Buy / Sell / Trade / eBay 2 02-15-2009 01:58 PM
Lathe and Mini Mill - Spare Belts - Getting an order together for UK Users CrewCab The Break Room 17 07-10-2008 10:06 PM
Home Made Lathe Projects rake60 Tools 1 10-08-2007 12:02 AM
