Home Model Engine Machinist > Building Them > Plans > 6-cylinder radial steam engine plans done and uploaded
Old 10-17-2011, 06:24 PM   #11
crueby
crueby's Avatar
Liked 154 Times on 94 Posts
Default Re: 6-cylinder radial steam engine plans done and uploaded
Thanks - plans and full build log are in the downloads section of the web site - it is on one of the later pages there.
Life's too short not to go sailing!
crueby is offline
Old 05-03-2012, 10:45 PM   #12
h_2103
It's looks like very good please a need the plans i can't find them can you help me
h_2103 is offline
Old 05-04-2012, 05:59 AM   #13
It seems the plans and build sequence are missing from the downloads section.
Old 05-04-2012, 09:05 AM   #14
mzetati
Liked 22 Times on 22 Posts
I was interested into reading the build log, no traces of "radial steam" or so in all the 25 pages of the download section.
Marcello
mzetati is offline
Old 05-04-2012, 10:30 AM   #15
crueby
crueby's Avatar
Marcello
I just looked -its there on page 21 of the downloads section, titled 6-cylinder radial engine build log.
The downloads area is not the easiest thing to search, but it is there.
crueby is offline
Old 05-04-2012, 10:44 AM   #16
mzetati
My bad!
And I checked the download pages twice.
Thank You
Marcello
To others interested, here's the link:
http://www.homemodelenginemachinist.com/index.php?action=tpmod;dl=item324
mzetati is offline
Old 06-23-2012, 07:49 PM   #17
michau32
Could you explain how valves work? I can't imagine it. Maybe you can attach some drawings?
michau32 is offline
Old 06-23-2012, 09:21 PM   #18
crueby
crueby's Avatar
The valves consist of a rod that is a close sliding fit in its hole, and the rod has two narrowed down sections that connect the piston to the air/steam inlet at the top of the stroke, and connects the piston to the exhaust at the bottom of the stroke. Rather than have an exhaust tube, the valve rod just extends out the top of the block, connecting the piston opening to the open air.
crueby is offline
Old 06-24-2012, 09:50 AM   #19
michau32
Thank you, now everything's clear. I'm going to build one.
Unfortunately I have only lathe so I'm going to make crankcase from hexagonal bar.
michau32 is offline
6-cylinder radial steam engine done and running crueby Finished Projects 16 02-19-2014 04:18 AM
6 Cylinder Radial Engine. Rocket Man Finished Projects 13 04-07-2012 04:36 PM
anyone have 18 Cylinder Radial Engine Drawings dj_monty Plans 4 04-13-2010 07:22 AM
Three Cylinder Radial Steam Engine SBWHART A Work In Progress 80 01-24-2010 01:46 AM
three cylinder radial engine dparker Photos and Videos 3 09-06-2008 09:31 PM
